Originally Posted by museumsteve You need to bear in mind that IR generally needs line of sight so if the socket is out of sight then IR could struggle (not always the case).
You could look at something like this? |
Wow that would be great because if you go on the website it actually shows that the IR receiver is very small and can be placed near the TV or something, So the sockets wont be visible! thanks alot!
Just to make sure as far as you are aware lights should Definitely with the Harmony one now?
Hopefully it wont be too hard setting them up with the Harmony one
[FONT=Times New Roman][/FONT]
