Home Easy @ B&Q - Cheap indoor pir's and sockets
Old 01-03-2009, 1:45 AM   #1
Godspeed's Avatar
4,748, Level: 16
Points: 4,748, Level: 16 Points: 4,748, Level: 16 Points: 4,748, Level: 16
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 133, Got 191
Just thought I would post to let fellow forum users know that my local B&Q store (EX8) has reduced a couple of home easy products - namely the indoor p.i.r remote control & socket set (he313) and the same remote control socket with a normal remote on/off switch (he317)
The pir and socket is £5 reduced from £20 barcode 5013529996780
The socket and remote on/off switch is £5 reduced from £10 (to follow)
Going down to the home easy section the pir is for sale on its own @ £20!
Looks like they have re-packaged the range and are selling off the old look kit at a reduced price.
Both items were hanging from those display 'strips' they have at the ends of isles with various different products on.
Worth checking out your local
Azzin (28-03-2009), RICKYJ (27-03-2009)
Old 24-03-2009, 8:04 PM   #2
Godspeed's Avatar
4,748, Level: 16
Activity: 3.4%
Re: Home Easy @ B&Q - Cheap indoor pir's and sockets
Apparently these packs are now reduced to £1 (hav'nt been to my local to check) - someone has picked one up from the Cortonwood store
RICKYJ (27-03-2009)
Old 28-03-2009, 12:55 PM   #3
Assured Advertiser
RICKYJ's Avatar
15,947, Level: 30
Points: 15,947, Level: 30 Points: 15,947, Level: 30 Points: 15,947, Level: 30
Activity: 9.8%
Activity: 9.8% Activity: 9.8% Activity: 9.8%
Thanks: Gave 1,024, Got 705
I can confirm that they were £1 in the Purley Way store. They were marked up as £19.98 (and I nearly walked out), but got a member of staff to scan each different set, and they came up as £1, so picked up a few (as am looking to automate the house) and went around the store picking up a few other bits.
By the time I got back to the isle (forgot a normal wall switch) they were all gone. Either the member of staff got/removed the last few, or another customer picked up a bargain.
Thanks for the heads up
Ricky
