Wanted: someone to try this on an Infinite Prime/Marmitek ProGuard 800 alarm syste
Old 24-02-2009, 2:10 PM   #1
2,081, Level: 10
Points: 2,081, Level: 10 Points: 2,081, Level: 10 Points: 2,081, Level: 10
Following on from my thread >>HERE<<, could anyone with either an Infinite Prime or Marmitek ProGuard 800 alarm who also is using X10 try the following for me:
1. Confirm that HA is enabled (menu [963]);
2. Switch the panel off at the mains for 1 second, then switch it back on;
3. See what happens.
This isn't long enough to trigger the AC LOSS system alert, but in my case the panel then sends an Off X10 command to every unit on my housecode
I don't know if this is deliberately (mis-)programmed in the firmware or if I have a faulty X10 module.
My hardware and software versions are (menu [710]) HW C0 SW 01.05
Old 02-09-2009, 9:05 PM   #2
3,052, Level: 13
Points: 3,052, Level: 13 Points: 3,052, Level: 13 Points: 3,052, Level: 13
Thanks: Gave 2, Got 0
Re: Wanted: someone to try this on an Infinite Prime/Marmitek ProGuard 800 alarm syst
Just read your message. I had the same problem earlier this year and was able to reproduce this at will. This will also happen when rescanning for modules or after a soft reset. After a lengthy discussion and further tests Marmitek has acknowledged this to be a bug.
A new HA module (new hardware) has been developed and sent to me about two weeks ago. It now works without the described problem.
