Shallow cavity downlights?
Old 03-02-2009, 7:19 PM   #1
Indecisive's Avatar
3,035, Level: 12
Points: 3,035, Level: 12 Points: 3,035, Level: 12 Points: 3,035, Level: 12
Thanks: Gave 33, Got 26
I would like to replace my out dated light fittings and install some halogen downlights but my problem is I only have a 7cm mounting depth. Is it possible? If so where can I get downlights that will fit in such a shallow cavity?
I am in a flat and the above floor is concrete so no fire risk to above floorboards.
Thanks for your help......
Old 18-02-2009, 6:03 PM   #2
1,653, Level: 9
Points: 1,653, Level: 9 Points: 1,653, Level: 9 Points: 1,653, Level: 9
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 7, Got 22
Re: Shallow cavity downlights?
You can buy a similar looking thing in a bar format from TLC Direct. This is surface mounting but to be honest I don't think it would look too great. Maybe don't fit downlights...
Halogen Under Cabinet Lighting
