Need light ideas
Old 04-10-2008, 7:27 PM   #1
geewhizz's Avatar
6,204, Level: 18
Points: 6,204, Level: 18 Points: 6,204, Level: 18 Points: 6,204, Level: 18
Thanks: Gave 173, Got 73
Need light ideas
I am planing a garage conversion and i cant think of lights to put on the the wall, I plan to put two light on one wall and two on the opposite but i dont know what to go for so any ideas appreciated.
Old 07-10-2008, 5:32 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: Need light ideas
ideas of types of lights or ideas for different ways to light a room? Which ever way you go I strongly suggest you go for controlled lighting rather than a dumb switch or rotary dimmer.
Old 07-10-2008, 7:35 PM   #3
kef1234's Avatar
3,018, Level: 12
Points: 3,018, Level: 12 Points: 3,018, Level: 12 Points: 3,018, Level: 12
Thanks: Gave 0, Got 7
http://www.avforums.com/forums/home-...me-cinema.html
My Led Lit Home Cinema
This is my post where i have been adding pics, I have been selling led lights for 12v use for 4 years now but recently started playing in the house. You can now use led's to light up hc rather than power thirsty bulbs. I also feel as though its more impressive when you use leds over bulbs because not everyone has seen them. I have some good contacts if you need some personal advice.
My advice is to use low level lighting if you have a projector and 100 % backlight your tv,it's better for your eyes at night.
