CCTV Questions
Old 29-09-2008, 4:06 PM   #1
3,822, Level: 14
Points: 3,822, Level: 14 Points: 3,822, Level: 14 Points: 3,822, Level: 14
Thanks: Gave 2, Got 0
CCTV Questions
Im working with a hotel and they want to add some wireless cams to their CCTV system, that's a multiplexor DVR and uses composite connections. The whole hotel has wireless and CAT5 everywhere.
Can anyone help me please.
Old 29-09-2008, 4:30 PM   #2
2,730, Level: 12
Points: 2,730, Level: 12 Points: 2,730, Level: 12 Points: 2,730, Level: 12
Thanks: Gave 7, Got 38
Re: CCTV Questions
Well, you've won the competition for the 'lack of information in a post'.
If you want some help, you need to tell us what you want help with. Have you purchased the cameras? What are they going to be used for? What make/model are they? Wireless Security protocol to be used? etc, etc, etc.
Old 29-09-2008, 9:30 PM   #3
vex vex is offline
10,371, Level: 24
Points: 10,371, Level: 24 Points: 10,371, Level: 24 Points: 10,371, Level: 24
Activity: 3.7%
Activity: 3.7% Activity: 3.7% Activity: 3.7%
Thanks: Gave 27, Got 252
Re: CCTV Questions
Unfortunately you are sort of mixing your technologies to much.
Assuming you are talking about Wireless Internet then this will be difficult to get to work. Composite and Wireless (internet) are two totally different standard.
SO your hotel will have to go one way of the other. Coax cable and power to use traditional ananloge CCTV cameras or and central PC with a range of IP Camers just hanign arround of the network.
HTH
V.
Old 29-09-2008, 9:44 PM   #4
Senior Moderator
Flimber's Avatar
20,385, Level: 34
Points: 20,385, Level: 34 Points: 20,385, Level: 34 Points: 20,385, Level: 34
Activity: 42.9%
Activity: 42.9% Activity: 42.9% Activity: 42.9%
Thanks: Gave 2,941, Got 2,447
Re: CCTV Questions
Maybe have this thread moved here ?
Old 29-09-2008, 10:58 PM   #5
Curly99's Avatar
138,437, Level: 89
Points: 138,437, Level: 89 Points: 138,437, Level: 89 Points: 138,437, Level: 89
Activity: 22.3%
Activity: 22.3% Activity: 22.3% Activity: 22.3%
Thanks: Gave 530, Got 1,462
Re: CCTV Questions
Good call thread moved.
Curly
Old 06-10-2008, 10:10 AM   #6
4,475, Level: 15
Points: 4,475, Level: 15 Points: 4,475, Level: 15 Points: 4,475, Level: 15
Thanks: Gave 1, Got 5
Re: CCTV Questions
well if they already have several analogue cameras, you could buy a hybrid DVR such as http://www.rfconcepts.co.uk/digital-...htm#HYBRID_DVR
That will support analogue cameras and IP cameras. No idea how well it performs, but depending on number of analogue cameras etc it might be a possibility.
