Adding a radiator ?
Old 27-09-2008, 7:04 PM   #1
geewhizz's Avatar
6,204, Level: 18
Points: 6,204, Level: 18 Points: 6,204, Level: 18 Points: 6,204, Level: 18
Thanks: Gave 173, Got 73
Adding a radiator ?
I am hopefully going to be adding a radiator to my garage when i convert it.
Right next to the garage i have a toilet with a radiator on the other wall, I was hoping i could add a spliter (or what ever they are called ) and run a pipe around the wall then drill a hole into the garage and connect a radiator to it.
Is it as easy as it sounds ?
I wont be doing it myself i will be getting a plumber to do it.
How much do you think it will cost ?
Many thanks
geewhizz
Old 27-09-2008, 7:38 PM   #2
wingnut121's Avatar
3,434, Level: 13
Points: 3,434, Level: 13 Points: 3,434, Level: 13 Points: 3,434, Level: 13
Thanks: Gave 114, Got 104
Re: Adding a radiator ?
basicly i would sergest a plumber to drain down, solder two tees and a lenght of copper isnt much work. price wise i wouldn't know cause i my gaffa does all pricing but your looking 1 to 2 hours if everything went swiftly and the plumber is keen.lol
geewhizz (27-09-2008)
