Basic automation starter kit....
Old 24-09-2008, 9:00 PM   #1
2,343, Level: 11
Points: 2,343, Level: 11 Points: 2,343, Level: 11 Points: 2,343, Level: 11
Thanks: Gave 0, Got 2
hi all,
i know ZERO about home automation but am keen to get going.
my harmony one should arrive tomorrow and i understand it can operate lights too.
do i simply need an x10 controller like this...
http://www.uk-automation.co.uk/mc10-...er-p-1160.html
and a wall switch?
http://cgi.ebay.co.uk/NEW-X10-Home-A...3286.m20.l1116
i could be well off the mark so really appreciate help!
john
Old 24-09-2008, 10:32 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: Basic automation starter kit....
ERm not that simple you will need X10 dimmers and a an IR to X10 interface then X10 wall switch if you want to keep the walll switch
Old 25-09-2008, 7:51 AM   #3
dunks517's Avatar
17,891, Level: 32
Points: 17,891, Level: 32 Points: 17,891, Level: 32 Points: 17,891, Level: 32
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 509, Got 479
Originally Posted by johnb2008 View Post
hi all,
and a wall switch?
john
John,
Is the wall switch single or double? One of those switches is ideal but ensure that is the light one and not the appliance one as the light one allows dimming and soft-on/soft-off. I have ordered from Kevin_Lo and have had a good service but get him to write 'gift' on the customs sheet as I was stung!!
The lights switches are really good and are marketed by Kevin_Lo as X10v2 but other UK sellers do them as Domia switches (www.simplyautomate.com) I use these in my house, they have a soft-on/soft-off feature and can remember the last dim level. Also they can still be used as a normal switch.
If you want to control the light from the Harmony One via infrared then the controller you should get is http://www.uk-automation.co.uk/infra...43-p-1164.html which allows ir signals to be received which then are outputted as X10 along the powerline.
When setting up your Harmony you must ensure that the other devices are set to do nothing so that when you switch the lights on the tv etc doesn't turn off. If you have problems with this then Logitech will be able to fiddle with your settings.
Regards
Duncs
Old 25-09-2008, 5:15 PM   #4
2,343, Level: 11
thanks, that is really useful.
will probably get those 2 bits
Old 01-10-2008, 10:09 AM   #5
4,329, Level: 15
Points: 4,329, Level: 15 Points: 4,329, Level: 15 Points: 4,329, Level: 15
Thanks: Gave 3, Got 44
I have a lot of X10 gears (some Kevin Lo, some Marmitek).
But if I could start again, I wouldn't bother.
I would just go for the B&Q HomeEasy range, and I would have been much happier.
Old 01-10-2008, 9:20 PM   #6
2,159, Level: 10
Points: 2,159, Level: 10 Points: 2,159, Level: 10 Points: 2,159, Level: 10
Thanks: Gave 10, Got 3
but the harmony won't operate the home easy range, as far as i know
