How to deliver 12V power over Cat 5 to Rako controls
Old 15-09-2008, 8:52 PM   #1
3,848, Level: 14
Points: 3,848, Level: 14 Points: 3,848, Level: 14 Points: 3,848, Level: 14
Thanks: Gave 2, Got 0
I have installed Rako rack systems in my new build, and all control points are wired with Cat5 for future upgrade to a full HA system (not yet selected). I have been told that I can power the RAko control points with 12V, rather than use batteries, and am now trying to work out how to get 12V into the cables at the head-end.
Does anyone know of a device through which I can patch the cables, to drive 12V into the unused pairs in the Cat5? Normal PoE is 48V and there are plenty of switches which do this, but I haven't found a model which can deliver 12V instead of 48!
Any ideas?.......or do you think I should just opt for battery power?
Regards,
Techpigmy
Old 16-09-2008, 6:47 AM   #2
vex vex is offline
10,368, Level: 24
Points: 10,368, Level: 24 Points: 10,368, Level: 24 Points: 10,368, Level: 24
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 27, Got 252
Re: How to deliver 12V power over Cat 5 to Rako controls
The batteries in Rako keypads are good for over 2 years and get shippes with them, so I wouldn't bother wasting your money.
THT - from my pda
V
Old 16-09-2008, 1:06 PM   #3
owain_thomas's Avatar
8,739, Level: 22
Points: 8,739, Level: 22 Points: 8,739, Level: 22 Points: 8,739, Level: 22
Thanks: Gave 79, Got 75
as Vex said just go for batteries, much easier and neater all round. very simple to change if/when they need doing.
Old 17-09-2008, 9:21 PM   #4
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Regards,
Techpigmy
have you tried asking your Rako supplier/installer it really isnt difficult
