Wireless Alarm?
Old 07-08-2008, 10:16 PM   #1
4,313, Level: 15
Points: 4,313, Level: 15 Points: 4,313, Level: 15 Points: 4,313, Level: 15
Thanks: Gave 1, Got 0
Wireless Alarm?
I've got a outbuilding I've converted in to an office - I want to put an alarm in it something which has a door sensor, 1 PIR and is wireless.
Can anyone suggest a good solution? Cost effective and with minimal wiring... (!)
cheers
I was thinking the BT solution or the Visonic PowerMax+ looks good - I could do the entire house - Assuming it's animal friendly... ?
Old 08-08-2008, 1:31 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: Wireless Alarm?
Visonic has animal friendly sensors, not sure about BT
Old 09-08-2008, 7:17 AM   #3
JohnS's Avatar
9,453, Level: 23
Points: 9,453, Level: 23 Points: 9,453, Level: 23 Points: 9,453, Level: 23
Thanks: Gave 6, Got 30
Re: Wireless Alarm?
I thought the BT one was a Visonic rebadged.
Old 16-08-2008, 11:11 PM   #4
samhain's Avatar
9,159, Level: 22
Points: 9,159, Level: 22 Points: 9,159, Level: 22 Points: 9,159, Level: 22
Activity: 7.6%
Activity: 7.6% Activity: 7.6% Activity: 7.6%
Thanks: Gave 124, Got 46
Re: Wireless Alarm?
We have a part wired alarm and part wireless, it was installed by Chubb and is serviced annually. The wireless sensors are on the windows and they have worked flawlessly, anyone who puts pressure of the years windows to try and get it and the small pin will activate the alarm. Works in test, hope I never need it otherwise.
