Home Automation software on Mac
Old 06-08-2008, 7:05 PM   #1
2,777, Level: 12
Points: 2,777, Level: 12 Points: 2,777, Level: 12 Points: 2,777, Level: 12
Thanks: Gave 11, Got 2
Does anyone know of any home automation software that runs on Mac OSX. I was looking at HomeSeer but it's Windows only, and I don''t want really want to run Parallels or VMware to run Windows on my Mac.
Old 07-08-2008, 8:30 AM   #2
2,676, Level: 12
Points: 2,676, Level: 12 Points: 2,676, Level: 12 Points: 2,676, Level: 12
Re: Home Automation software on Mac
I spent a while looking into this and decided to go with indigo - I must say up to now I have been very impressed. I haven't used many Windows based solutions but I would say that indigo is at least as good, if not better than most. Only downside I have found is the cost - the latest version will cost £100 but you can get the previous release for around £50. It has a web interface that I use in conjunction with an IPod touch to give me a great touchscreen remote. It also integrates well with ITunes, and other Mac applications as it uses apple script.
ellchester (07-08-2008)
Old 07-08-2008, 9:02 PM   #3
2,777, Level: 12
Thanks - I'll take a look.
