How do you get lights behind a TV?
Old 21-07-2008, 5:00 PM   #1
1,943, Level: 10
Points: 1,943, Level: 10 Points: 1,943, Level: 10 Points: 1,943, Level: 10
Thanks: Gave 20, Got 1
Hi I am a complete novice at this so any help is much appreciated.
I have looking at peoples rooms and kit setups and there are some which have TV’s and shelves which have low coloured lighting coming from underneath them or behind them.
I like the look of these and was wondering how it was achieved?
Are they plugged in or connected to the mains? For a simple setup with a couple of colours do you just buy the lights and plug them in or is there more to it than that? And could some one point me to a cheep website where I can get them from and what kit would I need for this.
Thanks for all your help.
Old 21-07-2008, 6:35 PM   #2
2,506, Level: 11
Points: 2,506, Level: 11 Points: 2,506, Level: 11 Points: 2,506, Level: 11
Thanks: Gave 1, Got 1
Re: How do you get lights behind a TV?
just a suggestion if you are looking for affect why not look at the ambilight range that will save on cables etc
MancNeil (21-07-2008)
Old 21-07-2008, 6:38 PM   #3
kef1234's Avatar
3,018, Level: 12
Points: 3,018, Level: 12 Points: 3,018, Level: 12 Points: 3,018, Level: 12
Thanks: Gave 0, Got 7
I have used a brand called iceled in my house.It is a 12v high output multicolour led product. If you go to Argos/maplins you can buy a 12v power supply for £5ish. I also used something called flexitape, it is a strip of leds in a thin waterproof jacket.It can be cut to length and uses little power. I have just bought some rgb led bars from him but they are not as light as the led tape for sticking to the back of the tv.
www.iceled.co.uk
I have a very experienced customer in sheffield who specialise in led lighting for cars called Source Sounds ( 01142571550). Speak to Lee or Paul they will look after you. They are top blokes. Tell them Pete from Celsus gave you there number.
http://www.sourcecars.com/index_new.html
Old 21-07-2008, 6:48 PM   #4
Pooon's Avatar
25,795, Level: 39
Points: 25,795, Level: 39 Points: 25,795, Level: 39 Points: 25,795, Level: 39
Thanks: Gave 238, Got 725
Something like this your looking for? clicky
Old 21-07-2008, 6:49 PM   #5
1,943, Level: 10
www.iceled.co.uk
Thanks for the help, I have just actually found your own post on the subject a couple of minutes ago...
Old 21-07-2008, 7:15 PM   #6
kef1234's Avatar
3,018, Level: 12
One thing i forgot to mention, be careful sticking heavy led bars to the back of your tv as they will generally fall off when the tv gets warm. I learnt that long ago.
