Duralite Rope Lights Sold By TLC-Direct - Why So Cheap?
Old 15-07-2008, 8:52 AM   #1
EViS's Avatar
13,403, Level: 27
Points: 13,403, Level: 27 Points: 13,403, Level: 27 Points: 13,403, Level: 27
Thanks: Gave 1, Got 50
Are the Duralite Rope Lights made up of LED's? I can't quite understand why they are so cheap (£1.80/m) compared to other rope lights which are in the £60/m bracket...
Also, any idea what their life is expected?
Old 15-07-2008, 8:54 AM   #2
dclayton's Avatar
3,557, Level: 14
Points: 3,557, Level: 14 Points: 3,557, Level: 14 Points: 3,557, Level: 14
Thanks: Gave 57, Got 44
Re: Duralite Rope Lights Sold By TLC-Direct - Why So Cheap?
No, these use bulbs rather than LEDs.
Old 15-07-2008, 8:58 AM   #3
EViS's Avatar
13,403, Level: 27
How about this Illuminated Flex? Again, substantially cheaper from other retailers?
Old 15-07-2008, 9:03 AM   #4
dclayton's Avatar
3,557, Level: 14
At 230V, these must use Bulbs also. LED's will be 12 or 24V.
Old 15-07-2008, 9:10 AM   #5
dclayton's Avatar
3,557, Level: 14
Ebay has some LED alternatives to rope light that are reasonably priced:
5M White LED light strip - £53.49
Or colour changing LED light strip with controller - £102.99 (£58.49 without controller) (as used here)
Or you can get 1.2 Meter White strips for £12.49
Old 15-07-2008, 9:12 AM   #6
EViS's Avatar
13,403, Level: 27
Thank you for confirming that. Could you give me some advice on where I can purchase some rope LED's lights? I require around 6 meters.
Old 15-07-2008, 10:49 AM   #7
4,515, Level: 15
Points: 4,515, Level: 15 Points: 4,515, Level: 15 Points: 4,515, Level: 15
Thanks: Gave 12, Got 42
Do you own a strip of these? no problems?
also it would be possible to hook this up so i can use a light switch as long as it was connected to a transformer link this or this wouldn't it? rather with a normal plug transformer?
Old 15-07-2008, 12:00 PM   #8
dclayton's Avatar
3,557, Level: 14
I own the colour changing LED's. Have had no problems at all, they are very bright!
I'm not sure about the current output of those transformers, on the ebay listing it states current/m = 0.4A for the LED's
This would be 0.4 x 12 = 4.8W per meter, or 24W for 5 Meters. The Minumum Power rating on the first transformer is 35W which is too high (not sure if it would cause any damage?), and for the second transformer the maximum is 9W, which is too low (if using all 5 meters).
