RGB everywhere...
Old 07-07-2008, 10:57 AM   #1
5,966, Level: 18
Points: 5,966, Level: 18 Points: 5,966, Level: 18 Points: 5,966, Level: 18
Thanks: Gave 10, Got 27
RGB everywhere...
....well not everywhere, but I do have a couple of questions on RGB lighting.
I'm after RGB lighting I can control and set (i.e. not on a continuous loop) for the following two applications and would appreciate any advice / manufacturer / retailer info you may have.
1. Internal wall washers for two walls (approx lengths 2.8m and 3.5m). The walls are in a new extension so wiring not an issue, but the ceiling is sloped giving different wall heights at one end to the other. Was looking at preferably a concealed system behind coving?
2. External wall washers. Need two external wall washers for a couple of brick walls (approx length 5m each) that face our garden to make more of a feature of them. May also want some smaller spots for highlighting plants.
Thanks in advance.
Dolph.
Old 09-07-2008, 8:40 AM   #2
MarkP80's Avatar
6,231, Level: 18
Points: 6,231, Level: 18 Points: 6,231, Level: 18 Points: 6,231, Level: 18
Thanks: Gave 112, Got 99
Re: RGB everywhere...
Hi Dolph,
Wise Chameleon might do the job for you. Relatively reasonable price for what it does (but RGB control is never cheap!)
Chameleon
If you're not bothered about remote control, then there's the Cromatix stuff -
Cromatix
all from LEDlightingproducts, with whom I have no affiliation but have received helpful advice from in the past.
Regards,
MarkP
Old 09-07-2008, 7:26 PM   #3
kef1234's Avatar
3,018, Level: 12
Points: 3,018, Level: 12 Points: 3,018, Level: 12 Points: 3,018, Level: 12
Thanks: Gave 0, Got 7
Have a look here at the rgb flexitape. www.litewave.co.uk
Old 15-07-2008, 12:55 PM   #4
dclayton's Avatar
3,557, Level: 14
Points: 3,557, Level: 14 Points: 3,557, Level: 14 Points: 3,557, Level: 14
Thanks: Gave 57, Got 44
For the internal walls you could use this. It comes with a controller including a wireless remote to change the colours. I've used the light strip here.
