Home security motion detection
Old 05-02-2008, 2:39 AM   #1
3,352, Level: 13
Points: 3,352, Level: 13 Points: 3,352, Level: 13 Points: 3,352, Level: 13
Thanks: Gave 6, Got 1
Hi, I don't know where to look for this info but I was looking at installing a motion detection sensor/trip beam of some sort to trigger a plug which would turn on a radio/table lamp for instance or multiple devices, for a given time limit maybe?
I'm 99% sure it can be done cheaply but it's finding a working solution that's hard to find on the net, any ideas very welcome. Thanks
Old 06-02-2008, 8:40 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: Home security motion detection
you need a break beam relay to control a device easy enough but not necassarily cheap
Old 07-02-2008, 11:28 AM   #3
1,976, Level: 10
Points: 1,976, Level: 10 Points: 1,976, Level: 10 Points: 1,976, Level: 10
Thanks: Gave 0, Got 5
You could use a MS13 motion detector, this sends an rf signal to a TM13 then converts it to an x10 signal turning on and off however many lights aplliances etc you require, or a pair of wired photocells providing an IR beam, when this is tripped it could pulse a powerflash module via a timer relay (X10 again) turn on lights etc,
Carlos
