Lutron metal backbox...for less than £50???
Old 27-01-2008, 1:03 PM   #1
Shockabuku's Avatar
21,771, Level: 35
Points: 21,771, Level: 35 Points: 21,771, Level: 35 Points: 21,771, Level: 35
Thanks: Gave 520, Got 163
Hi @. I'm trying to find a back box suitable for a Grafik Eye 3104, but as usual, Lutron prices are laughable...£50 anyone?!! . There must be something out there that'll do the job for a fraction of the price, surely...? Cheers.
Old 27-01-2008, 7:36 PM   #2
3,649, Level: 14
Points: 3,649, Level: 14 Points: 3,649, Level: 14 Points: 3,649, Level: 14
Thanks: Gave 21, Got 6
Re: Lutron metal backbox...for less than £50???
If you know the dimensions you could try your local electrical wholesaler. Edmundsons, Newey and Eyre, even RS Components. A standard metal clad backbox won't cost you anywhere near that money from those.
Dan
Old 28-01-2008, 11:05 PM   #3
X3ELS's Avatar
7,654, Level: 20
Points: 7,654, Level: 20 Points: 7,654, Level: 20 Points: 7,654, Level: 20
Thanks: Gave 12, Got 111
The 4 gang Jbox type? if yes drop me a pm mate i can point you in the right direction
