LED and Rako control
Old 25-01-2008, 9:38 PM   #1
4,875, Level: 16
Points: 4,875, Level: 16 Points: 4,875, Level: 16 Points: 4,875, Level: 16
Thanks: Gave 35, Got 15
I bought some small blue LEDs that are powered by a 12v mains adapter, I would like to make these part of a mood scene using the Rako controls.
They are not dimmable, just looking for on and off, does anyone know if Rako can control this and what unit is required.
Thanks in advance.
Old 26-01-2008, 1:24 PM   #2
vex vex is offline
10,368, Level: 24
Points: 10,368, Level: 24 Points: 10,368, Level: 24 Points: 10,368, Level: 24
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 27, Got 252
Re: LED and Rako control
Rako do a straight 800w switch module that is either On or Off.
I am going to use it to turn the none ecential TV kit off as I leave the room.
V.
Old 26-01-2008, 5:52 PM   #3
3,279, Level: 13
Points: 3,279, Level: 13 Points: 3,279, Level: 13 Points: 3,279, Level: 13
Thanks: Gave 14, Got 36
Use the Rako RDS800C. We use it al the time on LEDs. There is a small delay switching on and off but this can be adjusted from the Rako software. If you do not have the software, do not worry, the delay is almost negligible.
We have managed to dim an LED ropelight with an RDL250C. You have to open the RDL250C and cut a resistor on the board. Contact Rako to do this. Most LEDs though are not dimmable.
vex,
I would suggest not to use the RSD800C for your application. The 800c is only for lighting. I would use the RACUB and after that a bigger relay or conductor to switch on and off the load
Old 26-01-2008, 8:03 PM   #4
vex vex is offline
10,368, Level: 24
Activity: 4.2%
True, but the loading and in-rush / startup current isnt going to be that great.
Talking the Rako guys direct they suggested the 800. I'll talk to them more when I see them next week.
V.
Old 27-01-2008, 2:18 PM   #5
4,875, Level: 16
Thanks Charris, so if I use this unit would I put it prior to the main plug for the LEDs or after the LED mains plug?
Old 27-01-2008, 9:02 PM   #6
3,279, Level: 13
The Rako RDS800C needs 230V for power. It has to be installed before the transformer.
Old 28-01-2008, 9:16 AM   #7
vex vex is offline
10,368, Level: 24
Activity: 4.2%
Just to clarify Charris's correct post.
After the plug socket for the LEDs but before its transformer.
V.
Old 28-01-2008, 1:30 PM   #8
4,875, Level: 16
Thanks ALL - I think I get it, there is no seperate transformer, the mains plug has this built in.
So essentially like this...
Mains>>Rako>>LED Plug/Transformer
Thanks again, I'll get on ordering....
Old 28-01-2008, 3:46 PM   #9
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
you can use a standard dimmer if you edit the curve to be a switch useful with RAK4s (some LEDs use DMX or other systems) Rako have a solution for prtty much everything which is why they are so well loved...
av_101 (29-01-2008)
Old 28-01-2008, 7:52 PM   #10
4,875, Level: 16
Thanks Hornydragon, I guess you need the software to edit the curve of a dimmer right?
Old 28-01-2008, 9:10 PM   #11
3,279, Level: 13
Yes, you need Rakosoft
av_101 (29-01-2008)
