100W bulb in a 60W max ceiling light
Old 19-01-2008, 12:19 PM   #1
MSW MSW is offline
MSW's Avatar
2,377, Level: 11
Points: 2,377, Level: 11 Points: 2,377, Level: 11 Points: 2,377, Level: 11
Thanks: Gave 270, Got 180
At the top of my stairs I have an Ikea Ceilang Lamp which has a sticker on the inside that says 60W max.
Problem is that 60W is not bright enough for the stairs.
I have put in a 100W (20W energy saver), the lamp will be turned on for about 12 hours contantly. Used as a night light for kids.
Is there any real issue with puting a 100 (20W energy saver) in a fitting which is marked 60W, what will happen,
Mark
Old 19-01-2008, 12:25 PM   #2
2,438, Level: 11
Points: 2,438, Level: 11 Points: 2,438, Level: 11 Points: 2,438, Level: 11
Thanks: Gave 7, Got 16
Re: 100W bulb in a 60W max ceiling light
Mark
Mark, you will have no problem as long as you are using a low energy lamp.
The lamp rating is 20w and gives an equivelent light output of a traditional 100w bulb.
Lamp ratings are put on fittings mainly because of heat build up. If you put a higher wattage bulb in you risk excessive heat and potentially a fire.
Hope that helps
Nick
MSW (19-01-2008)
Old 19-01-2008, 12:43 PM   #3
MSW MSW is offline
MSW's Avatar
2,377, Level: 11
Hope that helps
Nick
Hi Nick, that heps an awful lot, I onyl changed the bulb this morning so, can sleep peacefully tonight.
Thanks for taking the time to reply
Mark
Old 24-01-2008, 9:10 AM   #4
marty2005's Avatar
80,106, Level: 69
Points: 80,106, Level: 69 Points: 80,106, Level: 69 Points: 80,106, Level: 69
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 5, Got 173
Them energy saving bulbs are crap really.
Don't they know that people have dimmer switches.
If you don't want an epileptic fit then don't use 'em.
They flicker like mad.
Old 24-01-2008, 10:10 AM   #5
5,329, Level: 17
Points: 5,329, Level: 17 Points: 5,329, Level: 17 Points: 5,329, Level: 17
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 33, Got 203
There are now fully dimmable energy saving bulbs from Varilight that can be dimmed with most electronic dimmers. They do cost about 3 or 4 times the price of standard low energy lamps but they do work surprisingly well
Standard energy saving lamps come with plenty of warnings not to use with dimmers, they can overheat (seen posts on the web of lamps with melted bases ), damage the dimmer, and also use as much energy as a normal standard lamp even when set to full output from the dimmer. So not a good idea
There are also fully dimmable GU10 & MR16 low energy replacements based on both fluorescent and LED technologies that have recently launched although you have to match theses carefully to the dimmers - some use 1-10v dimming control, others require trailing edge dimmers which are not as common as leading edge dimmers.
