Yale HSA 3095 Control panel battery replacement - where from?
Old 02-01-2008, 3:53 PM   #1
8,831, Level: 22
Points: 8,831, Level: 22 Points: 8,831, Level: 22 Points: 8,831, Level: 22
Activity: 6.4%
Activity: 6.4% Activity: 6.4% Activity: 6.4%
Thanks: Gave 996, Got 483
Yale can't help because they don't sell my alarm anymore apparently but I'm looking for a replacement for my control panel battery for my Yale alarm as it fails to hold a charge for more that 15 minutes or so (and not the quoted 8 hours approx).
On top of that, the alarm will not arm for approx 15 hours as the battery charges (force arm does not work) - rubbish I know.
Does anyone know where I can get a spare 7.2V 600mAh Ni-Cd replacement?
I've googled the P/N GP60AAS6YMX until my fingers have bled to no avail / contacted Yale / seached the forum etc.
Thanks in advance and happy new year all.
Old 02-01-2008, 6:03 PM   #2
gasspark
Posts: n/a
Re: Yale HSA 3095 Control panel battery replacement - where from?
Try Gardener Security, they are the largest security wholesalers in the UK, they may not have it in stock, but they will get it for you.
All the Best.
DJ Ovengloves (02-01-2008)
Old 02-01-2008, 6:35 PM   #3
8,831, Level: 22
Activity: 6.4%
will do - thanks!
Old 27-04-2010, 10:50 AM   #4
1,446, Level: 8
Points: 1,446, Level: 8 Points: 1,446, Level: 8 Points: 1,446, Level: 8
Slightly out dated but if your looking for batteries I might be able to help. I was looking for them myself.
There are dealers on eBay selling them if you search for HSA3001 or the battery number your looking for. The battery appears to be new and worked a treat.
The batteries listed from sellers are:
HSA6400 60AAAH6BMJ (or 802306063H)
HSA6300 60AAAH4BMJ
HSA3800 GP60AAS4BMX
HSA3095 GP60AAS6YMX
Old 27-04-2010, 11:41 AM   #5
1,947, Level: 10
Points: 1,947, Level: 10 Points: 1,947, Level: 10 Points: 1,947, Level: 10
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 3, Got 13
Try these guys in Swindon: The Battery Shop
They claim on their radio adverts that if they don't sell it, they will make it for you and if they can't make it... you don't need it!!
I haven't used them personally though so can't vouch for them.
