12vdc trigger to switch 240v socket
Old 23-12-2007, 10:53 AM   #1
2,441, Level: 11
Points: 2,441, Level: 11 Points: 2,441, Level: 11 Points: 2,441, Level: 11
Thanks: Gave 3, Got 15
Wink 12vdc trigger to switch 240v socket
I am multi-zoning my house and need a way to remotely switch on my amp upstairs Denon 3802, when triggered by the 12vdc trigger zone output of a Denon 3808 downstairs. Obviously I'll be running a hard wired connection between the two.
I've found stuff in the US made by Niles but it's expensive and also seems to be 110v.
Any ideas or will I have to try and make something.
thanks
R
Old 23-12-2007, 11:32 AM   #2
gasspark
Posts: n/a
Re: 12vdc trigger to switch 240v socket
just a quick thought
why not put a 12vdc coil relay between the 12v output switching the 240vac supply and 240vac amp.
Old 23-12-2007, 2:41 PM   #3
2,441, Level: 11
yep, trying to fing the best relay for the job now, any idea how many amps I'd need to switch?
R
Old 24-12-2007, 2:34 PM   #4
gasspark
Posts: n/a
20amp relay is more than needed
