Stereo audio over coax
Old 10-12-2007, 10:06 AM   #1
14,246, Level: 28
Points: 14,246, Level: 28 Points: 14,246, Level: 28 Points: 14,246, Level: 28
Thanks: Gave 167, Got 196
Just wondering if it's possible to send line level audio over CT100 coax? I have Cat 5 running to the same place, but at £100 for a pair of baluns I just want to see if using coax is cheaper....
Old 10-12-2007, 10:48 AM   #2
13,312, Level: 27
Points: 13,312, Level: 27 Points: 13,312, Level: 27 Points: 13,312, Level: 27
Activity: 54.2%
Activity: 54.2% Activity: 54.2% Activity: 54.2%
Thanks: Gave 1, Got 523
Re: Stereo audio over coax
If you have two spare CT100's, it's worth trying. The shielding on CT100 is designed for much higher frequencies than audio so I don't know how effective it would be at blocking 50Hz mains hum.
Failing that, and if you don't mind a bit of soldering, you can make a pair of CAT5 audio baluns.
You'll need four of these.
Steve
