Crabtree touch/Remote Dimmer Switch
Old 28-11-2007, 4:19 PM   #1
6,978, Level: 19
Points: 6,978, Level: 19 Points: 6,978, Level: 19 Points: 6,978, Level: 19
Thanks: Gave 24, Got 15
Hi i bought one of these a few weeks ago to replace the dimmer switch in my bedroom . I wired it up exactly as the instructions said but it didnt work properly when i went to turn the light on the light went to half brightness and that was it jus stayed that way could turn it of or on again . i checked the wiring and it was correct and still no joy , so then tried wiring differnt ways to the intructions and still wouldnt work so i took it back thinking it was faulty but the the new was the same . As i said i previously had a dimmer swith which i have refited and that works fine im now thinking of getting one of the lurton switches but i worried i'll have the same problem
Old 28-11-2007, 4:34 PM   #2
13,312, Level: 27
Points: 13,312, Level: 27 Points: 13,312, Level: 27 Points: 13,312, Level: 27
Activity: 54.2%
Activity: 54.2% Activity: 54.2% Activity: 54.2%
Thanks: Gave 1, Got 523
Re: Crabtree touch/Remote Dimmer Switch
What kind of lighting are you dimming?
I usually use the iQ dimmers from here
Old 28-11-2007, 4:55 PM   #3
6,978, Level: 19
Just a normal celling light like this
Old 28-11-2007, 5:08 PM   #4
13,312, Level: 27
Activity: 54.2%
That's pretty odd then! I don't have any real answer. Have you tried swapping the live and switched live connections over?
Steve
Old 28-11-2007, 6:02 PM   #5
6,978, Level: 19
i only have live neutral and earth
Old 28-11-2007, 6:31 PM   #6
13,312, Level: 27
Activity: 54.2%
Those wires aren't live and neutral, they are live and switched live. The black (or blue) wire should be sleeved with red (or brown) sleeving.
Try swapping those two wires round and see what happens.
Steve
Old 28-11-2007, 6:59 PM   #7
6,978, Level: 19
i have a red wire a black wire and earth wire on the switch it has 3 connections live , load , and slave . i connected red to the live connection and the black connection and i had the problem metioned above i the changed the cables around and got the same problem
Old 28-11-2007, 7:42 PM   #8
13,312, Level: 27
Activity: 54.2%
Some dimmers have a minimum load - what wattage lamps do you have installed in your fitting?
Old 28-11-2007, 7:50 PM   #9
6,978, Level: 19
it has 3 40w bulbs
Old 28-11-2007, 8:15 PM   #10
13,312, Level: 27
Activity: 54.2%
I'm at a loss to be honest. Perhaps you had two faulty units from the same batch?
Do you still have one of the units? Could you try it somewhere else in your house?
Steve
Old 28-11-2007, 8:43 PM   #11
6,978, Level: 19
have done again same problem
Old 28-11-2007, 8:44 PM   #12
13,312, Level: 27
Activity: 54.2%
I reckon you have been unlucky and got two with the same fault then...
