Simple CCTV requirements
Old 05-05-2007, 9:43 AM   #1
LDJ LDJ is offline
LDJ's Avatar
5,815, Level: 18
Points: 5,815, Level: 18 Points: 5,815, Level: 18 Points: 5,815, Level: 18
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 4, Got 4
Hi guys,
Im looking to buy two cameras that I want to mount at home that will allow me to monitor my (vacant) property during the day. I want to set one facing the driveway/garage (so I can see when anyone comes to the house) and one inside the house, or maybe on the back of the house.
I therefore need two cameras that are both wireless and waterproof. I dont want to spend a fortune, but need to be able to connect up and view the images from the web - whether that be a live stream or snapshots sent by FTP/email etc.
Can anyone recommend something suitable?
Old 10-05-2007, 4:11 PM   #2
3,239, Level: 13
Points: 3,239, Level: 13 Points: 3,239, Level: 13 Points: 3,239, Level: 13
Thanks: Gave 2, Got 0
Re: Simple CCTV requirements
quite a few cameras on maplin.co.uk that may meet your requirements
Old 10-05-2007, 4:36 PM   #3
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
well sounds like IP cameras are the way to go can be wireless (still need power) i would run some cat5 and 2 exterior IP cams there are other opions but none as sweet look at panasonic they include the software and everything to view from the web with the cams
Old 13-05-2007, 1:59 PM   #4
LDJ LDJ is offline
LDJ's Avatar
5,815, Level: 18
Activity: 2.0%
Are there? I cant find any wireless IP cctv cameras on Maplin ?
Old 21-05-2007, 3:42 PM   #5
JagoPlasma's Avatar
12,664, Level: 27
Points: 12,664, Level: 27 Points: 12,664, Level: 27 Points: 12,664, Level: 27
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Thanks: Gave 847, Got 387
any particular reason why you need wireless?
you will get a much better and cheaper selection if you go wired
Old 21-05-2007, 4:01 PM   #6
LDJ LDJ is offline
LDJ's Avatar
5,815, Level: 18
Activity: 2.0%
I could go wired i guess, I was thinking wireless purely because it would save me running an ethernet cable outside to the garage. That said, i guess i could use one of the homeplug ethernet adapters to run the signal through if there's already electricity going to the garage couldn't i?
In that case then, i'd just need a good outdoor IP CCTV camera that I can monitor from the web.
Any suggestions?
Old 21-05-2007, 4:05 PM   #7
Assured Advertiser
63,997, Level: 61
Panasonic BB HCM 331 http://www.panasonic.co.uk/ip-cameras/bbhcm331.html comes with everything you need to make it work over the internet and is Day/Night spec you can pan move the cams remotely as well
Old 21-05-2007, 4:25 PM   #8
LDJ LDJ is offline
LDJ's Avatar
5,815, Level: 18
Activity: 2.0%
Yeah, looks the business. But at >£300 its a bit out of my price range!
Old 21-05-2007, 4:41 PM   #9
Assured Advertiser
63,997, Level: 61
what is your price range?£100? will struggle i think could use http://www.maplin.co.uk/Module.aspx?...=CCTV&doy=21m5 but then you need web interface http://www.digidave.co.uk/product_in...roducts_id=105 so £220+
Old 21-05-2007, 5:17 PM   #10
LDJ LDJ is offline
LDJ's Avatar
5,815, Level: 18
Activity: 2.0%
Thanks for all the info. I have a media center PC running 24/7 - is there any OSS that I could use to handle the uploading of images etc to save a few pennies?
Can you use the homeplug adapters with wired cameras? Would save the added expense of wireless and also greater reliability.
Old 21-05-2007, 5:19 PM   #11
Assured Advertiser
63,997, Level: 61
havent tried but dont see why homeplug wouldnt work
Old 26-05-2007, 6:13 PM   #12
3,273, Level: 13
Points: 3,273, Level: 13 Points: 3,273, Level: 13 Points: 3,273, Level: 13
yes you could use homeplug but unless you've got a couple lying around thats gonna cost you another £85 or so (if i remember the prices correctly).
depends what premium the wireless is.
Personally i'd go wired over homeplug any day, far more reliable than wireless.
Unfortunately outdoor ip cameras are still a bit expensive, another option is to buy a camera enclosure and put a normal ip camera inside that?!
Old 27-05-2007, 10:44 AM   #13
bobsplace's Avatar
7,446, Level: 20
Points: 7,446, Level: 20 Points: 7,446, Level: 20 Points: 7,446, Level: 20
Thanks: Gave 53, Got 47
If your running a server,put a Geovision card in your pc.
You can buy one second hand ,then you can use any camera.
Viewing over the web is a breeze and will give you recording playback etc also.
Old 01-06-2007, 6:43 PM   #14
5,241, Level: 17
Points: 5,241, Level: 17 Points: 5,241, Level: 17 Points: 5,241, Level: 17
try webcam xp, good little program for remote viewing you can download a trial version and it's very easy to set up, works with ptz cameras as well.
http://www.webcamxp.com/
hope this helps
Old 02-06-2007, 2:05 PM   #15
paigessii
Posts: n/a
Thanks for uploading this, it gave me something to read on my lunch break.
DVD Software
http://www.hotdvdtools.com
