Remote Dimmers and Spotlights...
Old 11-04-2007, 4:08 AM   #1
3,575, Level: 14
Points: 3,575, Level: 14 Points: 3,575, Level: 14 Points: 3,575, Level: 14
Thanks: Gave 15, Got 32
http://www.maplin.co.uk/Search.aspx?...source=15&SD=Y
Firstly, anyone any experience with the above ?
My room has a single standard light at the moment, im interested in changing this, was thinking of an uplighter, but might be tempted to change for some spotlights. My room is fairly small, so 5 would be enough (1 in the center where the light is now, and 4 towards the corners). As i understand, the spots daisy chain, so id put the centre one in first, then link the other 4 ? Do i chase the wire from in the room ? or would i have to go into the attic (upstairs bedroom) ?
Would the 5 dimmers then be operable from the single switch ? and be fine with a dimmer ?
Any advice appreciated.
Old 11-04-2007, 10:37 AM   #2
4,102, Level: 15
Points: 4,102, Level: 15 Points: 4,102, Level: 15 Points: 4,102, Level: 15
Thanks: Gave 1, Got 21
Re: Remote Dimmers and Spotlights...
The remote is fine Smiths are a respected name.There are loads of others too in various finishes.
To wire the spots ........do you mean cutting holes in the celing and them being flush (GU10s) if so done from the loft.
You almost never chase out a ceiling.You would need a 20amp 4 way JB and some 1.00mm or 1.5mm CABLE (not flex).
I do this sort of thing every day,so its easy and I have all the tools (obviously).
If you are new to it please be careful....oh and knock off the lighting breakers or remove the fuse carriers if its an old board.
Apologies if you know all this already.
Steve
Old 11-04-2007, 10:44 AM   #3
4,102, Level: 15
Sorry forgot if 5 x GU10 @50watts thats 250 watts the dimmer is rated at 300Watts .
So yes to the last question
Old 11-04-2007, 5:25 PM   #4
4,518, Level: 15
Points: 4,518, Level: 15 Points: 4,518, Level: 15 Points: 4,518, Level: 15
Thanks: Gave 12, Got 42
have you checked out varilight remote dimmers there IR too and can be had in much better finishes for the same kind of money
Old 11-04-2007, 7:21 PM   #5
4,102, Level: 15
Hi Hi Def
Yeah absolutely correct,but I didnt want to confuse matters.
I thought it might be getting a bit complicated as it was.
Steve
Old 12-04-2007, 9:43 PM   #6
Rob_Meister's Avatar
4,313, Level: 15
Points: 4,313, Level: 15 Points: 4,313, Level: 15 Points: 4,313, Level: 15
Thanks: Gave 80, Got 36
Yeah check the varilight dimmers out at www.tlc-direct.co.uk
