CCTV Problem
Old 10-04-2007, 2:22 PM   #1
sjack
Posts: n/a
CCTV Problem
Bought a single camera CCTV unit from Argos, cheap and cheerful one.
I cant record footage unless I leave the television on the AV channel.
What am I doing wrong?
Thanks.
Old 10-04-2007, 2:33 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: CCTV Problem
erm record onto what? if using VHS i suggest you connect camera to VHS (or DVD-R) then view on TV via recorder
Old 10-04-2007, 2:34 PM   #3
5,545, Level: 17
Points: 5,545, Level: 17 Points: 5,545, Level: 17 Points: 5,545, Level: 17
Activity: 3.9%
Activity: 3.9% Activity: 3.9% Activity: 3.9%
Thanks: Gave 73, Got 209
Re: CCTV Problem
Go on, give us a clue. What are you trying to record onto? How is it connected to your TV?
If you tell us what your TV is, what your recorder is and how they are connected we might be able to help you.
regards
Brian
EDIT : must type quicker, must type quicker
Old 10-04-2007, 2:51 PM   #4
sjack
Posts: n/a
Re: CCTV Problem
Sorry to be vague.
Camera plugged into VCR and connected to TV via Scart.
Old 10-04-2007, 2:55 PM   #5
Assured Advertiser
63,997, Level: 61
Re: CCTV Problem
OK so when you reord if you dont get camera on tape what do you get?
Old 10-04-2007, 4:03 PM   #6
sjack
Posts: n/a
Re: CCTV Problem
I just get blank tape, or if I tune the TV into BBC1 I get that, only when the TV is tuned to AV, the VHS is also tuned to record AV, do I get footage from the camera.
Old 11-04-2007, 8:32 AM   #7
3,664, Level: 14
Points: 3,664, Level: 14 Points: 3,664, Level: 14 Points: 3,664, Level: 14
Thanks: Gave 1, Got 8
Re: CCTV Problem
Is it possible to swap the scart connections the other way around on the video to see if that makes any difference? It sounds like you are recording the feed from the tv via scart.Maybe you have to record on av2
Old 11-04-2007, 9:25 AM   #8
sjack
Posts: n/a
Re: CCTV Problem
Yes, spot on.
Thanks to all, top site with top advice.
Old 12-04-2007, 8:00 AM   #9
3,664, Level: 14
Re: CCTV Problem
Glad to see you got it sorted.
