Originally Posted by hornydragon points to consider with a distributed system input control you need to know if the IR outputs are discrete if they arent you cant have 2 of the same component ie cant use 2 Denon Tuners. |
I got hold a 3 input Nuvo tuner in 1 box, so that 3 of my inputs gone if I connect all 3 up! I still haven't found if the IR inputs are discrete on the Concerto, but I suspect they might be as thaey are supplying a 3 O/P tuner themselves.
Originally Posted by hornydragon with IR only you dont get feed back with RS232 you get feedback but few components have RS232, the lack of feedback can be a real pain with a server full of music. |
Nuvo does it's own music server, although it is a bit pricey. It seems to use a proprietary interface to communicate with the Concerto (called NuvoNet). The RS232 seems to be reserved for basic home automation, although there doesn't seem to be much information about this. It seems that Nuvo and HAI have went into a joint venture and are compatible. Both are US companies, so I don't know that much about what the boxes are capable of when interlinked. As for a music server, I might go down the Media center PC route for storing music rather than buying the Nuvo M3 music server, as it be more flexible and would have more storage (and should be able to control it via RS232).
Talking about RS232, I got hold of a cheap Crestron AV2 video controller on eBay. I was going to incorporate this into my home automation system, but hit a problem as the software for it is only available to dealers and registered installers. Now I know why they go cheap on eBay!!
Originally Posted by hornydragon there are huge number of systems out there picking the right one is incredibly difficult making it work 10times harder. |
How right you are!!
I've now virtually committed myself to buying Nuvo, as I've already bought the Nuvo 3 O/P tuner and I've also bought some Nuvo speakers. The in-room controllers are what really sells this system. They use clever touch technology in place of real buttons and the display is bright and has a good viewing angle.
