Urgent need needed. Need to buy cheap LED Lighting
Old 27-03-2007, 11:06 PM   #1
Illustrious Member
BenchyUK's Avatar
47,248, Level: 53
Points: 47,248, Level: 53 Points: 47,248, Level: 53 Points: 47,248, Level: 53
Activity: 47.3%
Activity: 47.3% Activity: 47.3% Activity: 47.3%
Thanks: Gave 395, Got 933
Hi guys
Sorry to start a new thrread but looking through other threads it seems too compicated to undertsand
This weekend i am pimping out my room on a budget and want to get some Blue Lighting to go behind my 32'' LCD that's on the wall
I have no idea what kind of lighting? Is it LED that i need? or how it all works. No idea how many lights i need either
I would like one that can be turned on and of with a remote.
If i was really stretched, i can spend around £50 on the lot. f it does require more money but looks good and does the remote function then i can spend more.
I need to order soon and would like them delivered within a week
Old 28-03-2007, 1:38 PM   #2
rdhanjal
Posts: n/a
Re: Urgent need needed. Need to buy cheap LED Lighting
I picked up a remote control mains socket switch from Maplins a few weeks back.
It was about £5. Basically, I think the easiest way is if you get some LED rope light, plug it into the maplin's box, which then plugs in to a mains socket.
Not sure what the best rope light for you is tho, but the whole lot should be a lot less than £50.
Old 28-03-2007, 3:23 PM   #3
Illustrious Member
BenchyUK's Avatar
47,248, Level: 53
Activity: 47.3%
Thanks. I heard about the Plug adpater that uses a remote. That may be a good option.
Can someone help and point me in the direct of lighting
Old 28-03-2007, 4:13 PM   #4
4,501, Level: 15
Points: 4,501, Level: 15 Points: 4,501, Level: 15 Points: 4,501, Level: 15
Thanks: Gave 4, Got 5
Can you get to Ikea (Lakeside) Lee?
Old 28-03-2007, 4:21 PM   #5
Alun's Avatar
8,068, Level: 21
Points: 8,068, Level: 21 Points: 8,068, Level: 21 Points: 8,068, Level: 21
Thanks: Gave 303, Got 259
Think I know where your coming from.
LED strips, 4 for £15 IIRC.
Just put some under the bairns bed and they look awesome.
Calls it his 'fast and furious' bed
Come in four 8" strips complete with sticky back foamy stuff and all relevant connections, switches and powers upplies
Old 28-03-2007, 4:23 PM   #6
Illustrious Member
BenchyUK's Avatar
47,248, Level: 53
Activity: 47.3%
I wanted to just order them off the net. I didn't want to travel for them. Plus lakeside is quite a way away
Old 28-03-2007, 5:44 PM   #7
4,501, Level: 15
Trettion Light strips, £21. Easy. But you gotta go to Ikea!
Old 29-03-2007, 9:47 AM   #8
5,329, Level: 17
Points: 5,329, Level: 17 Points: 5,329, Level: 17 Points: 5,329, Level: 17
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 33, Got 203
I'd go for rope light - see this stuff from TLC Electrical as an example.
It is supplied in cut lengths and is run directly from the mains without a transformer (remember to order the mains connection kit!). Fix the rope to the wall rather than the screen and it works very well. It's even dimmable if you need to adjust the light output.
Old 03-04-2007, 3:14 PM   #9
mhuk05's Avatar
14,581, Level: 29
Points: 14,581, Level: 29 Points: 14,581, Level: 29 Points: 14,581, Level: 29
Thanks: Gave 31, Got 128
Someone on the forum sells LED lighting; can't remember who but search should find them
