cctv supplier wanted?
Old 08-03-2007, 8:53 AM   #1
SASCL
Posts: n/a
I'm after suppliers for the following 2 cctv dvr's:-
dvr365 16 channel dvr
system2 16 channel dvr
Apart from systemq for the dvr365 who else supplies the above equipment. It is not a problem if it is a trade only supplier.
Cheers.
Old 08-03-2007, 9:16 AM   #2
bilge's Avatar
3,763, Level: 14
Points: 3,763, Level: 14 Points: 3,763, Level: 14 Points: 3,763, Level: 14
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 8, Got 7
Re: cctv supplier wanted?
http://www.quadrantcctv.com
I've used these people in the past for video kit...
They seem to be more a systems supplier now
it might be worth giving them a ring anyway
Old 08-03-2007, 9:18 PM   #3
4,292, Level: 15
Points: 4,292, Level: 15 Points: 4,292, Level: 15 Points: 4,292, Level: 15
Activity: 6.7%
Activity: 6.7% Activity: 6.7% Activity: 6.7%
Originally Posted by SASCL View Post
You could try these http://www.cctvmart.co.uk/catalog.as...7;20Monitoring
They seem to do the 365, and why would you not buy from system Q.
Old 08-03-2007, 9:57 PM   #4
3,715, Level: 14
Points: 3,715, Level: 14 Points: 3,715, Level: 14 Points: 3,715, Level: 14
Thanks: Gave 7, Got 11
DVR365's are manufactured for SystemQ by Dahua Technology Co Ltd (www.dahuatech.com). Until recently Dahua distributed in the UK under the name Dational. Unfortunatley these are no longer available.
SystemQ are the official UK distributor now.
cctvmart.co.uk appear to be selling the old model 365!
I've never come across system2 DVR's?, did you mean Smart2?
Old 09-03-2007, 2:50 PM   #5
SASCL
Posts: n/a
sorry i meant smart2
I didn't realise systemq were the official distributor. Now I know
Old 09-03-2007, 4:10 PM   #6
3,715, Level: 14
SystemQ distribute Smart2
Old 29-03-2007, 3:07 PM   #7
Alex Saunders
Posts: n/a
I used a company in Nottingham alot called Speed Alarm Ltd. They will get you anything you want a a great price, and they accept credit cards. Tel (0115) 9780791
Old 19-03-2008, 10:09 AM   #8
2,536, Level: 11
Points: 2,536, Level: 11 Points: 2,536, Level: 11 Points: 2,536, Level: 11
The DVR365 is also known as the original manufacturer marketing code as the 3004/8/16 dependant upon channels.
Try this company, they supply the DVR's in question, I've had loads and they're a great piece of kit, better replay than a DM!!
Acorn Fire & Security Tel: 01254-207532
www.acornfiresecurity.com
