Cocked Up Light Switch
Old 19-02-2007, 12:56 PM   #1
4,364, Level: 15
Points: 4,364, Level: 15 Points: 4,364, Level: 15 Points: 4,364, Level: 15
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 8, Got 29
Ive just fitted a new Crabtree made Satin Chrome single touch dimmer to a bedroom and when I was fitting the new pattress the plaster around the switch fell apart (should have known better really) . Anyway the upshot is Ive just ruined the new wallpaper around the lightswitch thats just been done. Rather than replace the whole strip of wall paper I wanted to see if I can find a back plate / finger plate in Satin Chrome finish to cover the mess. Any ideas anyone. Ive looked all over the place and just cant find what Im after.
Old 23-02-2007, 4:23 PM   #2
4,102, Level: 15
Points: 4,102, Level: 15 Points: 4,102, Level: 15 Points: 4,102, Level: 15
Thanks: Gave 1, Got 21
Re: Cocked Up Light Switch
Firstly I dont understand why you are using a pattress?isnt it flush?
Regards the fingerplate.......
You need to go to a helpful WHOLESALER not B&Q etc who MAY be able to help.
These are easily avalble in brass but not so sure about other finishes.
Regards
steve
