Plasma Backlight?
Old 06-09-2002, 6:24 PM   #1
10,265, Level: 24
Points: 10,265, Level: 24 Points: 10,265, Level: 24 Points: 10,265, Level: 24
Plasma Backlight?
Anyone got any good ideas how i can backlight a plasma please?
Old 06-09-2002, 6:31 PM   #2
jmack
Posts: n/a
mine is wall mounted i have been thinking of backlighting it with either that rope lighting or i seen a pic some where of some one who put a neon strip behind his
have a look at the gallery pics on the www.avsforum.com
http://translate.google.com/translat...8%26oe%3DUTF-8
its about the 5th pic down
hope this helps
Old 06-09-2002, 6:36 PM   #3
10,265, Level: 24
Cheers Jmack avsforums is where i got the idea from , havnt seen rope lighting is this easilly obtainable?
Old 06-09-2002, 6:41 PM   #4
jmack
Posts: n/a
ive just looked on maplins site could not find it but will still search
did u look at the bottom link that guy got a nice set up.
i think a rope type lighting would give a better light than the neon strip on each side of the panel
Old 06-09-2002, 10:05 PM   #5
ReTrO's Avatar
15,958, Level: 30
Points: 15,958, Level: 30 Points: 15,958, Level: 30 Points: 15,958, Level: 30
Thanks: Gave 14, Got 51
You can get rope light from Homebase most of the year round. they do most colours, though it may be a bit long.
Old 06-09-2002, 11:32 PM   #6
Miniholic's Avatar
12,662, Level: 27
Points: 12,662, Level: 27 Points: 12,662, Level: 27 Points: 12,662, Level: 27
Thanks: Gave 537, Got 398
Argos sell, rope lighting, saw it in the catalogue this afternoon, when my girlfriend was looking for some speaker stands. Thankfully I managed to talk her out of the £9.99 ones though! Taking her to a proper shop tomorrow.
Old 07-09-2002, 11:10 AM   #7
10,119, Level: 24
Points: 10,119, Level: 24 Points: 10,119, Level: 24 Points: 10,119, Level: 24
The Argos stuff seems to be multicoloured and a bit nasty.
Some of the overclocking stores sell it as a case mod, but I guess it would be 12V - quite expensive too!
What about the kitchen cupboard strip lights you get? They seem to have a "warmer" light than neon tubes, and they are fairly low profile, too.....
Old 13-10-2002, 4:03 PM   #8
10,265, Level: 24
Im going to try white christmas tree lights! should be easy to hide.
Old 13-10-2002, 4:24 PM   #9
10,119, Level: 24
I nearly suggested that but thought I'd get laughed at.
Never tried, but can you run them off a dimmer - I don't see why not, as they're normal bulbs at 240V. Might do something similar round our fixed PJ screen....
Old 13-10-2002, 8:40 PM   #10
10,265, Level: 24
Im going to wire them to a dimmer switch so i can control them with my rc 5000, will try and post a pic if it works ok.
Old 14-10-2002, 7:12 AM   #11
10,119, Level: 24
Animated GIF of the dim in action, please
That's what I was kind of thinking of for myself.
