hd x 4 over cat5e
Old 24-01-2007, 8:11 PM   #1
4,277, Level: 15
Points: 4,277, Level: 15 Points: 4,277, Level: 15 Points: 4,277, Level: 15
Thanks: Gave 7, Got 4
hd x 4 over cat5e
i would like to distribute sky hd over sheilded cat5e to at least 4 tv's,
is this possible.
cheers simon
Old 24-01-2007, 8:32 PM   #2
Assured Advertiser
Joe Fernand's Avatar
36,526, Level: 46
Points: 36,526, Level: 46 Points: 36,526, Level: 46 Points: 36,526, Level: 46
Activity: 25.4%
Activity: 25.4% Activity: 25.4% Activity: 25.4%
Thanks: Gave 205, Got 1,344
Re: hd x 4 over cat5e
Hello simon123
You can use an HDMI Distribution Amplifier in tandem with HDMI over CAT5 extenders to send SD and HD signals to Two or more Displays.
Gefen have a range of Single and Multiple Input HDMI Distribution Amps in formats including 1x4 and 1x8 along with HDMI over CAT5 extenders. See http://www.gefen.com/kvm/product.jsp?prod_id=3354 and http://www.gefen.com/kvm/product.jsp?prod_id=3872
If you require a bit more control/flexibility you can pre switch multiple Sources into the Distribution Amp using a Switch - see http://www.gefen.com/kvm/product.jsp?prod_id=3447
Alternatively you can have a 4x4 Matrix (Any Source to Any Display - http://www.gefen.com/kvm/product.jsp?prod_id=3331) or a 2x4 combined Switch and Distribution Amp (Same Source to all Displays - http://www.gefen.com/kvm/product.jsp?prod_id=3045).
You will also need to make provision for IR control alongside the HDMI Distribution - if you have a third CAT5 cable you can run a Xantech or similar system alongside the HDMI system.
Joe
Old 24-01-2007, 9:20 PM   #3
5,651, Level: 17
Points: 5,651, Level: 17 Points: 5,651, Level: 17 Points: 5,651, Level: 17
Thanks: Gave 2, Got 1
I've got smart-e
8x8 supports up to 1080p and even higher resolutions.
its great
got it from www.intelligent-living.co.uk
Old 24-01-2007, 9:35 PM   #4
Assured Advertiser
36,526, Level: 46
Activity: 25.4%
Hello rich1231
I thought the Smart-e 'HD' products were yet to be released; the SNX models are billed as 'up to' 1600x1200!
Joe
Old 25-01-2007, 12:44 AM   #5
5,651, Level: 17
I have it running in my house at the moment so its here alright.. was installed about 5 months ago anf works brilliantly
Old 01-02-2007, 12:16 PM   #6
3,081, Level: 13
Points: 3,081, Level: 13 Points: 3,081, Level: 13 Points: 3,081, Level: 13
Thanks: Gave 20, Got 2
How much does this system cost if you dont mind me asking!?
Old 01-02-2007, 1:53 PM   #7
vex vex is offline
10,368, Level: 24
Points: 10,368, Level: 24 Points: 10,368, Level: 24 Points: 10,368, Level: 24
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 27, Got 252
Do you want one input to multiple outputs or multiple inputs to multi outputs?
Either way I was with AudioAuthority at an exhibiton in Amsterdam yesterday and they have both systems available at amazing prices.
IIRC the single source multi room HD compatible system over 2 cat5e's is about £650 + Installation. For the hub and six locations from memory.
Multisource / multi room is up arround £3500.00 but still using the same faceplates and two cat5e cables.
Old 01-02-2007, 3:16 PM   #8
ntslik's Avatar
12,410, Level: 26
Points: 12,410, Level: 26 Points: 12,410, Level: 26 Points: 12,410, Level: 26
Thanks: Gave 0, Got 12
Depends on your budget, but check out the Livingcontrol system, has HD video switching
Old 01-02-2007, 6:04 PM   #9
Assured Advertiser
36,526, Level: 46
Activity: 25.4%
Hello Paul_GPvR
UK SRP for an 8x8 YUV with IR control starter pack based around the Smart-E SNX-8x8 is 5.6K (ex VAT).
Joe
Last edited by Joe Fernand; 02-02-2007 at 10:50 AM. Reason: New 2007 pricing - with support for 1080p up to 100m on screened CAT5.
Old 02-02-2007, 12:01 AM   #10
5,651, Level: 17
The whole system... well there is alot of kit
the co i got it from supplied it all and the only niggle i had was the IR switching, which was fixed by a firmware fix (and now is std)
The smart e came just under a year ago and was 5 ish at the time, but when i bought it it was only 720p and 1080 i confirmed, now pretty much everything is possible over it
i had my house wired for everything, and so the cabling process was painful but everything works amazingly.. only a few more items to go then the place doesnt need me in iot to function
Old 06-02-2007, 2:14 PM   #11
3,393, Level: 13
Points: 3,393, Level: 13 Points: 3,393, Level: 13 Points: 3,393, Level: 13
Netstreams Panorama will do the job for you. It can distribute HD images from 4 sources to six outputs up to 1000 feet. This is all achieved using CAT5e cables.
Old 21-02-2007, 9:17 AM   #12
4,987, Level: 16
Points: 4,987, Level: 16 Points: 4,987, Level: 16 Points: 4,987, Level: 16
Simon - coming soon to a UK Xantech distributor near you :-
http://www.xantech.com/products/p_folder/p_hd44cc5.htm
Also be very wary of Gefen products when connecting to Yamaha/Denon amps.
Adam
