Morpheus light
Old 21-01-2007, 8:21 PM   #1
13,972, Level: 28
Points: 13,972, Level: 28 Points: 13,972, Level: 28 Points: 13,972, Level: 28
Thanks: Gave 27, Got 45
Morpheus light
Has anyone got one of these? They look good, was thinking of one perhapseither in a corner or behind my plasma, any advise me whether they are decent?
http://www.theglowcompany.co.uk/acat...EUS_LIGHT.html
Old 21-01-2007, 10:46 PM   #2
hpoom's Avatar
9,070, Level: 22
Points: 9,070, Level: 22 Points: 9,070, Level: 22 Points: 9,070, Level: 22
Thanks: Gave 36, Got 18
Re: Morpheus light
Yep I have looked at those before too, if anybody had one I would love to know if it is any good.
Old 23-01-2007, 8:43 AM   #3
MarkP80's Avatar
6,231, Level: 18
Points: 6,231, Level: 18 Points: 6,231, Level: 18 Points: 6,231, Level: 18
Thanks: Gave 112, Got 99
Re: Morpheus light
Hi guys,
I've got one of these, sat in the corner of my lounge. I rather like it. It's not in direct line of sight, but sort of to one side and behind a bit. The unit is out of sight behind a sofa. I'd say it's around the size of a shoebox.
The light output isn't massive - when the wall lights are on, the effect is lost really. However, when we watch something on tv we like to have the lights off, and the Morpheus gives a nice ambient background, much better than sitting in the pitch black. I'd say it would be fine behind a tv, in an ambilight sort of way, but not if you have other lights on - you'd be wasting your time IMHO.
You can have it scrolling through different colours, or fix it on one - there are 3 LEDs in it of different colours.
If you were thinking of say a dining room, then it would be nice with candlelight, but again, not a bright centre light. Maybe Morpheus in one corner and a small lamp in an opposite one.
Hope that helps,
MarkP
