Ikea LED Lighting
Old 14-07-2006, 9:15 AM   #1
2,625, Level: 11
Points: 2,625, Level: 11 Points: 2,625, Level: 11 Points: 2,625, Level: 11
Ikea LED Lighting
Has anyone bought a set of these? http://www.ikea.com/webapp/wcs/store...umber=30098175
How good are they compaired to others, seam a good price for 4x 31cm/12" tubes
Old 14-07-2006, 8:40 PM   #2
Daddy k's Avatar
14,101, Level: 28
Points: 14,101, Level: 28 Points: 14,101, Level: 28 Points: 14,101, Level: 28
Activity: 15.5%
Activity: 15.5% Activity: 15.5% Activity: 15.5%
Thanks: Gave 374, Got 286
a lot of us are using them behind our plasmas matey.
iv got a blue set. take a peak at the plasma thread and search in there for trettieon light
theyre pretty good
Old 14-07-2006, 8:45 PM   #3
Daddy k's Avatar
14,101, Level: 28
Activity: 15.5%
infact as im bored i found it out for ya. go to:Trettioen Lights (plasma Bling)
Old 15-07-2006, 1:25 PM   #4
hornz's Avatar
2,414, Level: 11
Points: 2,414, Level: 11 Points: 2,414, Level: 11 Points: 2,414, Level: 11
Thanks: Gave 10, Got 15
I bought a blue set last week and I'm very impressed. Compared to other solutions I've seen recently they're excellent value for money.
Old 16-07-2006, 3:40 PM   #5
sapper's Avatar
20,094, Level: 34
Points: 20,094, Level: 34 Points: 20,094, Level: 34 Points: 20,094, Level: 34
Activity: 19.3%
Activity: 19.3% Activity: 19.3% Activity: 19.3%
Thanks: Gave 432, Got 139
Remote Control
Is it possible to control these lights on/off via remote control?
Old 17-07-2006, 3:52 PM   #6
12,135, Level: 26
Points: 12,135, Level: 26 Points: 12,135, Level: 26 Points: 12,135, Level: 26
Thanks: Gave 5, Got 99
Hello.
The Ikea lights are not a bad budget solution. I find them to be a bit spotty in some installs.
I would recomend my own product in the power buys section, it costs a little more at £27 for the full kit (AVForums Price), but you get a much brighter spread of lights.
I will also be selling LED kits hopefully in a couple months, similar to the IKEA kits, but that comes with a remote, and allows you to change colours etc..
Old 21-07-2006, 8:54 AM   #7
2,625, Level: 11
They look great, but your kit only includes 2 lighting strips, I would need four
