CCTV for garage
Old 11-05-2006, 12:10 PM   #1
18,290, Level: 32
Points: 18,290, Level: 32 Points: 18,290, Level: 32 Points: 18,290, Level: 32
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 119, Got 135
CCTV for garage
I am looking to portect my garage with CCTV. It is a free-standing garage within about 10 metres of the house.
I am ideally looking for something with a motion sensor that will send the images wirelessly to a PC in the house. The garage has power so I can power the camera but would not have any recording gear down there.
Does this sort of thing exist?
Old 11-05-2006, 12:44 PM   #2
Sydney's Avatar
2,410, Level: 11
Points: 2,410, Level: 11 Points: 2,410, Level: 11 Points: 2,410, Level: 11
Thanks: Gave 23, Got 10
Smile
Nokia do a product that is a remote camera which when detects motion will send a photo to your mobile or email address. It is called the PT-6. See attached link for further info. http://www.nokia.co.uk/nokia/0,8764,90120,00.html Its the dogs danglys. Hope this helps.
Old 11-05-2006, 12:51 PM   #3
4,453, Level: 15
Points: 4,453, Level: 15 Points: 4,453, Level: 15 Points: 4,453, Level: 15
Thanks: Gave 7, Got 25
If you have internet access from your garage (WiFi) you could use a network camera like this. A bt on the expensive side but does everything you want. It doesnt require a PC to be on and will email you or FTP images/video when it detects motion.
I bought two of these for my house and they work well. Do a search on eBay for network cameras and there are quite a lot out there but you the more you pay the better they are.
Old 11-05-2006, 1:28 PM   #4
fabbers's Avatar
3,031, Level: 12
Points: 3,031, Level: 12 Points: 3,031, Level: 12 Points: 3,031, Level: 12
Thanks: Gave 1, Got 8
If you do have wifi then one of these http://www.bigpockets.co.uk/product....c3ea82561e25a1 and a security light with pir might sort you. I take it you want to put this IN the garage otherwise external cameras get pricey.
Camera review here - http://www.reghardware.co.uk/2006/04...ternet_camera/
Old 21-03-2007, 9:25 PM   #5
davehewitt
Posts: n/a
Re: CCTV for garage
Sorry to jump in, but im looking at viewing my drive after a few problems and have decided on the axis 207 camera. Just wondering where the best (cheapest) place you guys get them from
I have found
http://www.securitywarehouse.co.uk/c...n&currency=GBP
http://www.lambda-tek.com/components...prodID=1092125
http://www.icode.co.uk/icatcher/cctv...t=dept_22.html
but i dont understand why there is such a gap between them. I have tried kellkoo, price runner etc but cant find them any cheaper. Are they really that expensive?
Old 22-03-2007, 9:01 AM   #6
4,453, Level: 15
Re: CCTV for garage
I bought my 207W camera off ebay (came from a shop www.powerkeycomputing.com), it was competative at the time.
Just had a quick look at the links you provided and they look competitive.
