Ceiling PIR Light
Old 23-04-2006, 2:29 PM   #1
11,992, Level: 26
Points: 11,992, Level: 26 Points: 11,992, Level: 26 Points: 11,992, Level: 26
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 181, Got 193
Ceiling PIR Light
Hi there,
I'm looking for a Ceiling Based PIR Light. It's going to be installed in a fairly sized doorless cupboard which will contain my DVD's, and would like to avoid installing a switch as it will interrupt my shelving!!
Thanks very much/...
Old 23-04-2006, 2:54 PM   #2
sbowler's Avatar
11,173, Level: 25
Points: 11,173, Level: 25 Points: 11,173, Level: 25 Points: 11,173, Level: 25
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 131, Got 497
Tricky. You could use one of these,
http://www.argos.co.uk/static/Produc...2Blighting.htm
there designed for outdoor but I think they look ok. If its for the roof then its not a lot of good. Sorry, could you buy a detector and wire it into the light on the roof and then fix the detector to the wall?
Old 23-04-2006, 5:18 PM   #3
mickymcd's Avatar
5,130, Level: 16
Points: 5,130, Level: 16 Points: 5,130, Level: 16 Points: 5,130, Level: 16
Thanks: Gave 80, Got 37
you still need a switch to isolate the light you install somewhere in line though you can purchase a 230v pir to switch any type of light these can be bought from most electrical wholesalers etc.Or use a lantern type or bulkhead as the previous poster said .
