You’re probably dead on Zog, I'm unsure about the cost of Xenon lighting and I want want to push something if there is a cheaper option. I got a supplier to price some lights for richjthorpe.
I would also like to add my understanding of LED lights. They are difficult to dim because they use so little power and most dimmers cant dim past 20Watts ( you might be able to get one that can cheap but I don’t know a CE marked one)
That’s why people put loads in their garden, with so many the wattage builds up and they can dim them,
Typically a small amount of LEDs is very difficult to dim, and when they dim, they just dim, they don’t change colour.
My understanding of RGB Mixing is based on ON OFF control, i.e. different batches of LEDs are switched on and off at different times. In fact most of the LED lights we install look very colourful like these
http://www.lew-host.co.uk/product_in...roducts_id=243
and the colour change types like these
http://www.loweleds.com/plazalamps.html
You can actually see the different colour LEDS. If you want blue then all the blue turn on, if you want red then all the red, and they are mixed with those colours along those lines, no frequency changes or voltage drops just plain old on/off.
I'm sure that if we went "down this route" we would find the more expensive fittings that regulate different elements but most of the standard LED colour change fittings are cheap and use ON OFF control, we have installed a a donkey load of these types of fittings.
I have priced some T5 fitting and you are correct Zog they are pricy
Fitzgerald fittings MLP14/HF/ED €65.14 up to MLP35/HF/ED @€69.98
I know these are Euro prices but these are UK products so you guys should get them cheaper, as for T5 light being cr@p that is a matter of opinion, they are specified for the display lights in Blockbuster Movie shops, many chains of bookies, Premark, B&Q etc and most cost aware office blocks use them as a working light.
They are very bright as per the request of the OP and as they all have their dimmers built into the fitting there is no buzz, when they are dimmed they save power and money as they don’t dissipate energy and heat through a
resistor.
Please nore I'm no expert on Xenon or flexi neon lights, I have however found it to be pricy when i was looking for it, but lighting is like that, if a supplier thinks hes specified he'll screw you on it, by the sounds of it Zog has good prices on the stuff, and its possible to install the stuff in curvy areas.
What ever happens I'm sure it will look the biz, best of luck with it.
