Big breath - Long Post!
Hi Barefoot,
Sorry I missed you post, but here are my thoughts on what you are trying to do. btw I think Ulti is a great product for the retro fit market and think we can make it fit here.
QUOTE=barefront
I have 6 rooms to fit
Living room
a 4 circuit switch - porch, single wall light, 2 wall lights and main ceiling light
b 2 circuit switch - upstairs landing and downstairs 2nd main ceiling
a. I assume you planned the 4 circuits to be wired back to two single gang two circuit dimmers or where they going to be straight on/off switches? At the moment dimmers only come as 1 or 2 circuits in a single gang backbox.
b. The 2 circuit switch is easy using a standard single gang, two circuit dimmer or switch.
Landing
a 3 circuit switch - (dual switch with living room b switch) main landing, downstairs 2nd main, picture uplighter
MMmmmm, tricky, You could wire straight ULTI switches to the dual switch with the lounge B circuit but you can not do it with dimmers but dimmers will give you the scene setting mooding lighting stuff. The way round it would be to have the switch/dimmer at one end and a 'freelocate' switch (wall remote) at the other. This would give the effect of a twin switched circuit with out the hassel of wiring for one. The odd ball is how to control the third circuit, the picture uplighter. One option would be to 'hide' the dimmer or switch for that one somewhere (cupboard under the stairs, in the loft) and have that controlled off the freeloacte switch as well.
3 bedrooms
a 2 circuit switch - wall and ceiling
Simple two circuit, single gang dimmer or switches
Kitchen
a 2 circuit switch - undercupboard/worktop light, 6 low voltage downlighters
Again a simple 2 circuit, single gang dimmer or switches
I am looking in retro fit into standard wall metal masonry boxes, single and twin. I have two switches that have dual switched circuits on them (downstairs main and Landing). I would like to have scene abilities.
The beauty of Ulti is it fits into standard uk back boxes, the thing that lets it down is they need flipin deep ones to sit flush. 47mm ! Each switch is shipped with some stand offs but these only bring you out to 35mm-ish
I dont have neutral at the switches and I cant get them there easily (just finished laying floors and plastering walls/ceiling, controllable lighting was an afterthought.
I was looking at the UTLI range http://www.ulti.biz
which seemed to cover most of my bases. apart from a twin 4 way or 3 way dimmer.
The real question in all of this is
1. Are there any alternatives to suggest, I looked at rako but I dont think I can easily hide the dimmer modules, with the ULTI ones they are all built in.
2. Does anyone know where to get the installation/technical literature, i need to check sizes, compatibility with low voltage etc.
Compatibility with low voltage is fine, providing that the transformers are speced as dimmerable.
What install / tech stuff are you looking for? Install and programming is very simple and you do not need a neutral.
Chris
(ulti wholesaler)
