IR remote dimmer switches
Old 28-02-2001, 5:59 PM   #1
Arthur.S
Posts: n/a
Post
Letsautomate only seem to sell X10 stuff or Lutron(Expensive)
www.baldyplex.com
Old 28-02-2001, 8:52 PM   #2
General Skanky's Avatar
17,672, Level: 32
Points: 17,672, Level: 32 Points: 17,672, Level: 32 Points: 17,672, Level: 32
Thanks: Gave 24, Got 31
Post
I'll find my receipts etc and let you know exactly where and how much.
Douch!!......Wot's da madder, da CIA got you pushing too many penzils?
Work: www.hughes-tv.co.uk
Old 28-02-2001, 8:53 PM   #3
Paul D's Avatar
20,544, Level: 34
Points: 20,544, Level: 34 Points: 20,544, Level: 34 Points: 20,544, Level: 34
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 132, Got 284
Post
Heres a link to the page for cheap IR dimmers
http://www.letsautomate.com/10163.cf...&cftoken=18287
These dimmers are the same as the ones at maplins but cheaper!. These should fulfil your needs fine.
I bought one but didn't like the single button control, ie press once - on, press once - off, press and hold dim up/down.
When using a universal remote it did't know if the lights were on or off.
I stumped for the £98 Lutron, it has seperate buttons for on/off up/down four preset light levels, plus soft(fade) on/off.
The macro on the remote (Sony RM-AV2000T - £80 Richersounds) can be set to "play DVD dim/off lights" or "Stop DVD lights up/on" etc.
I'am not drinking anymore....but i'am not drinking any less
Old 01-03-2001, 12:32 AM   #4
4,221, Level: 15
Points: 4,221, Level: 15 Points: 4,221, Level: 15 Points: 4,221, Level: 15
Thanks: Gave 7, Got 15
Question IR remote dimmer switches
I'm looking for an online store which sells basic IR dimmer switches (not anything fancy - just a basic one will do just fine) I know Argos used to sell them, but not any more...
Thanks,
retro
Old 01-03-2001, 12:39 AM   #5
7,884, Level: 21
Points: 7,884, Level: 21 Points: 7,884, Level: 21 Points: 7,884, Level: 21
Thanks: Gave 15, Got 36
Post
Try www.maplin.co.uk
They have some for £33 which supposedly include anti TV/Video interference devices.
I haven't tried them so I'm not sure what they're like.
Slingshot
Old 01-03-2001, 12:45 AM   #6
17,672, Level: 32
Post
You are in luck.
Firstly, do a search on the forum and you'll find a whole host of replies to this exact topic.
But for speed, I bought one at £25 approx.
Go to www.letsautomate.co.uk and you'll get what you want. I bought my first one elsewhere, but it's cropping up all over at £25 - £30 or so.
I have two now and they are both fine.
It's the one that can be used in one of 4 zones with the same remote. Very simple to use and install.
You'll need to buy either a recessed wall pallette or a 25mm box one (I think that's the depth) to put on your wall. I had 16mm (?) boxes, both were changed. Replacements cost about £1 +/-, depending where you buy one from, Homebase, Wickes etc. The standard size is not deep enough to accomodate the recess of the dimmer's internals.
E-mail me for any more info if you need it.
[This message has been edited by General Skanky (edited 28-02-2001).]
Old 01-03-2001, 9:12 AM   #7
4,221, Level: 15
Wink
Thanks for all the info folks.
I went with Maplin in the end, as letsautomate.com have some ridiculous delivery charges when shipping outside the UK.
Cheers,
-retro
Old 01-03-2001, 8:14 PM   #8
17,672, Level: 32
Post
Fulabeer,
they are the ones I have and my Pronto is fine with them. No problems.
Old 02-03-2001, 12:52 AM   #9
Paul D's Avatar
20,544, Level: 34
Activity: 6.1%
Post
No offence meant (General Sanky). If your lights were already off and you pressed play (macro) it would turn your lights on! etc where as the lutron has dedicated up down commands so if the lights were off and you pressed play(macro) the lights would just stay off....Paul
Old 03-03-2001, 12:52 AM   #10
17,672, Level: 32
Post
None taken.
I see what you mean now. I haven't set up any macros yet. But obviously there is that to look out for.
Thanks for the tip.
Old 03-03-2001, 11:26 AM   #11
7,282, Level: 20
Points: 7,282, Level: 20 Points: 7,282, Level: 20 Points: 7,282, Level: 20
Thanks: Gave 4, Got 1
Question
Does anybody have any experience of X10 Auto dimmers .I have a lighting plate with 3 dimmers [Manual] which I would like to replace with automatic control .Any suggestions .Jim
Old 03-03-2001, 5:12 PM   #12
Timh's Avatar
22,950, Level: 36
Points: 22,950, Level: 36 Points: 22,950, Level: 36 Points: 22,950, Level: 36
Activity: 7.4%
Activity: 7.4% Activity: 7.4% Activity: 7.4%
Thanks: Gave 183, Got 82
Post
Hi All
Do these infer red dimmers buzz, like the old manual ones do.
cheers
Tim
You are not Jadzia....Jadzia has gone to Stovacore
Old 03-03-2001, 11:44 PM   #13
Paul D's Avatar
20,544, Level: 34
Activity: 6.1%
Cool
I have several IR dimmers around the house both cheap and dear(lutron) and none of them buzz loudly. From about foot away i can't hear anything.
Listening from about two inches away on full dim the cheap ones give a very slight buzz.
The manual rotary ones i've heard can be heard from two/three feet away!.
Different makes of IR dimmers are louder/quiter but still quieter than manual ones.......IMHO!
Reality is just an illusion caused by the lack of alcohol....
