Home automation with MCE
Old 03-06-2005, 10:36 AM   #1
9,347, Level: 23
Points: 9,347, Level: 23 Points: 9,347, Level: 23 Points: 9,347, Level: 23
Has anyone experimented yet with Windows Media Center Edition (MCE) and home automation?
I'm about to install my home cinema system into the lounge and that means running cables, plastering, new flooring the works and was contemplating installing a home cinema PC using Windows Media Center Edition.
I'm also interested in setting up some lighting themes / automation too.
Now I've seen a few reviews of Convergex in magazines where they have produced a snap in for MCE called Living Rooms. You can control appliances, lights heating etc. Anyone know how much this is, i can't seem to find any info.
I'm initially interested in lighting and a thermostat controller for the boiler...
Anyone got any ideas / contacts?
cheers
Simon
Old 04-06-2005, 12:57 PM   #2
4,575, Level: 16
Points: 4,575, Level: 16 Points: 4,575, Level: 16 Points: 4,575, Level: 16
Thanks: Gave 2, Got 14
...have a look at Homeseer - they have plug ins for MCE now too.
Homeseer has been around for ages....
DJ
Old 06-06-2005, 6:48 PM   #3
5,329, Level: 17
Points: 5,329, Level: 17 Points: 5,329, Level: 17 Points: 5,329, Level: 17
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 33, Got 203
You might also be interested in a company called Sensible Heat - they are Honeywell Hometronic installers and are working on a MCE plug in and interface to allow the Honeywell system to be controlled from MCE. I don't think it will be too long before they also have an interface to a major lighting control manufacturer so will be bale to cover both bases. Take a look at www.sensibleheat.co.uk for info.
Old 23-06-2005, 10:14 PM   #4
brettgriffin
Posts: n/a
Have you consdiered HAI. It is manufactured in the States, but it is 50hz. They have a nice media center interface, I use. It allows me to control lighting (multiple protocals), my HVAC, and my alarm system.
HAI is the leader in Home automation, and has distribution worldwide. Check them out at www.homeauto.com
Old 24-06-2005, 5:48 AM   #5
4,525, Level: 15
Points: 4,525, Level: 15 Points: 4,525, Level: 15 Points: 4,525, Level: 15
mControl by Embedded Automation
Please also check out mControl by Embedded Automation (http://www.embeddedautomation.com/EAHAmControl.htm)
Ted
