Best price for lutron
Old 20-05-2005, 12:15 PM   #1
Bashy
Posts: n/a
Hi I was wondering if antone new were I could get a good price for a lutron grafik eye 3104
Old 20-05-2005, 1:09 PM   #2
6,610, Level: 19
Points: 6,610, Level: 19 Points: 6,610, Level: 19 Points: 6,610, Level: 19
Thanks: Gave 5, Got 21
The best price I've found is from these guys:
http://www.rbstaronline.co.uk/acatal...rafik_Eye.html
Who appear to want £366.80 + VAT for it.
Overall, a quote I got from them for 3 grafik eyes, 6 control panels and some backboxes worked out at about 1/3 less than retail list price.
I've not bought anything from them yet, as my house build has been delayed, so I can't say anything about their service level, but they've responded quickly to my emails.
Rowland
Old 20-05-2005, 1:16 PM   #3
Bashy
Posts: n/a
thanks for the reply. do u know if there is anything else out there like lutron apart from zen and rako
Old 20-05-2005, 4:39 PM   #4
Xstyle's Avatar
12,026, Level: 26
Points: 12,026, Level: 26 Points: 12,026, Level: 26 Points: 12,026, Level: 26
Activity: 3.2%
Activity: 3.2% Activity: 3.2% Activity: 3.2%
Thanks: Gave 171, Got 103
There is also Futronix:
Lutron vs Futronix vs Rako
or for more lighting options, go to :
www.audiovisiononline.co.uk
and speak to Nigel, I've been chatting to him recently about lighting...
Regards,
Sid (aka Xstyle)
Old 23-05-2005, 4:28 PM   #5
ntslik's Avatar
12,410, Level: 26
Points: 12,410, Level: 26 Points: 12,410, Level: 26 Points: 12,410, Level: 26
Thanks: Gave 0, Got 12
Regards,
Sid (aka Xstyle)
Or Neil even
Old 31-05-2005, 10:44 AM   #6
Xstyle's Avatar
12,026, Level: 26
Activity: 3.2%
Originally Posted by ntslik
Or Neil even
Thats what I meant!!
Fantastic service!!!!
Impartial advice on all the brands.
thanks NEIL
Old 31-05-2005, 11:33 AM   #7
JUS JUS is offline
JUS's Avatar
9,111, Level: 22
Points: 9,111, Level: 22 Points: 9,111, Level: 22 Points: 9,111, Level: 22
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 42, Got 99
[QUOTE=Xstyle]There is also Futronix:
QUOTE]
I've got a few futronix switches. They look really nice. one spot light bulb blew, when I flicked the circuit breaker back on all the spots stayed on full after talking to Futronix they said I need to pay £58+vat to get it fixed and I should use a specific type of bulb going forward. The switch was fitted by a qualified electrician who also supplied the bulbs (16 months ago). Who wants a light switch so fragile it breaks if you don't get exactly the right bulb?
Jus.
Old 31-05-2005, 11:49 AM   #8
JUS JUS is offline
JUS's Avatar
9,111, Level: 22
Activity: 1.5%
Neil,
Can you please tell me what you would recommend as a replacement for the P100 I have? Preferably similar dimensions, cost, have at least 2 channels, easy to use (6 year old daughter and visitors need to be able to use) but a bit more robust.
Regards,
Justin
Old 10-06-2005, 9:03 AM   #9
2,512, Level: 11
Points: 2,512, Level: 11 Points: 2,512, Level: 11 Points: 2,512, Level: 11
Thanks: Gave 1, Got 1
Another alternative
Anyone looking for an alternative to Lutron (and others) might like to consider the Nikobus system. See:
www.niko.be
Old 24-09-2007, 6:17 AM   #10
4,893, Level: 16
Points: 4,893, Level: 16 Points: 4,893, Level: 16 Points: 4,893, Level: 16
Thanks: Gave 5, Got 42
Re: Another alternative
www.niko.be
Anybody here have any experience of Nikobus or Niko lighting?
I have a few thousand to spend on lighting automation for the new house.
Niko seem a fair bit cheaper than Lutron or Helvar.
Any other brands to consider?
Old 24-09-2007, 10:41 AM   #11
5,329, Level: 17
Points: 5,329, Level: 17 Points: 5,329, Level: 17 Points: 5,329, Level: 17
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 33, Got 203
Re: Best price for lutron
[QUOTE=JUS;1706963]
QUOTE]
Jus.
The problem is that a filament lamp can pull an enourmous amont of current for a brief moment when it blows which is why you get a very bright flash from the lamp. This damages the triacs used by Futronix and other lighting control manufacturers who use triacs for their dimming technology. I'm sure if you look at the Futronix documentation that they specify internally fused lamps which the major brands use (such as GE, Osram etc) but these cost more than the cheap unbranded lamps which are generally not fused. The internally fused lamps can help give some protection but they are not a guarantee that you will never damage the triac.
Old 29-09-2007, 10:29 AM   #12
1,712, Level: 9
Points: 1,712, Level: 9 Points: 1,712, Level: 9 Points: 1,712, Level: 9
Activity: 3.7%
Activity: 3.7% Activity: 3.7% Activity: 3.7%
Thanks: Gave 0, Got 8
I have experience of Niko and Lutron.
They are quite different products but. The Niko is less expensive (but actually not that much less) and is a "broader" solution in that it offers audio additions and some control. Belgian in origin, the system is widely deployed in hotels (particularly in Belguim). Lighting control works well, is fairly easy to install and program. The modules are DIN rail mountable. Keypads allow you to control lighting and Niko audio controlers and offer wireless options. Scenes and lighting levels can be controlled by the user and even set manually on the modules using a small screwdriver. Keypad styles are very continental in appearance, and you either like em or you don't!
Lutron (homeworks) is lighting only, although offers conditional logic and some very useful control capabilities, but doesn't pretend to be anything else. Keypad options are much more varied. Grafik eye installations can be extended and evolved into Homeworks. The systems are cabled differently.
This is a very very brief summary of two systems that would take a few pages to do any real justice to, so I would recommend you look at the web sites for further information.
Hope this helps
Old 01-10-2007, 2:08 PM   #13
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
IS there a complete rewire going in Cyril (either refurb or new build?) if so look at iLight as another option if its not a full rewire then Rako is the best solution. Depends what else your planning (multiroom AV/CCTV access control?) Niko may or may not be supported by other systems (crestron, netstreams etc)
Old 01-10-2007, 2:39 PM   #14
ntslik's Avatar
12,410, Level: 26
www.niko.be
The only thing that bothers me with Niko is it looks like it's designed for a 3 year old or and adult with an IQ of a 3 year old
Old 17-10-2007, 12:40 PM   #15
1,712, Level: 9
Activity: 3.7%
Yes. Belgian designed, for hotels. It isn't pretty, although some people don't seem to mind. Lutron offer a great range of control styles and finishes. I know which one I would go for (and I am biased), but other considerations, not least the price usually have a bearing. The Lutron controls require a J-box to fit into which is quite deep by UK standards.
Old 18-10-2007, 8:58 PM   #16
2,117, Level: 10
Points: 2,117, Level: 10 Points: 2,117, Level: 10 Points: 2,117, Level: 10
Thanks: Gave 6, Got 8
Look into Mode Lighting, few great products, Scenestyle 4 and their homeworks style Mode Evolution. UK built, bomb proof.
Old 23-10-2007, 3:21 AM   #17
4,893, Level: 16
It's a full rewire of a Victorian house.
I was thinking of multi-room audio, but a Sonos seems a likely candidate.
Mutiroom video is required, but only to 3 rooms, only 2 rooms requiring HD.
For energy efficiency I would like to use as many LED lights as I can.
I need just 2 CCTV cameras.
Old 23-10-2007, 11:53 PM   #18
3,289, Level: 13
Points: 3,289, Level: 13 Points: 3,289, Level: 13 Points: 3,289, Level: 13
Thanks: Gave 4, Got 8
This place, billing itself as the 'Lutron Shop' seems quite well priced.
Old 25-10-2007, 11:29 AM   #19
dazzler9000's Avatar
4,537, Level: 15
Points: 4,537, Level: 15 Points: 4,537, Level: 15 Points: 4,537, Level: 15
Thanks: Gave 57, Got 31
Try this place http://www.mr-resistor.co.uk/controls.aspx?t=260
They sell at good prices and the very helpful chap even gave me an unexpected discount while ordering on the phone.
