Backlighting
Old 01-04-2005, 12:27 PM   #1
thegooseman
Posts: n/a
Smile Backlighting?
Does anyone know where I can get some 'mood' backlighting that reacts to whats on the pannell??
Or if not just some funky backlights.
Old 01-04-2005, 3:09 PM   #2
7,514, Level: 20
Points: 7,514, Level: 20 Points: 7,514, Level: 20 Points: 7,514, Level: 20
Thanks: Gave 1, Got 1
The only things i can think of are led lights that are designed to change colour. These can be fitted into the floor or ceiling or as uplighters. Use google images(mood lighting led lights)
Old 01-04-2005, 3:11 PM   #3
w3dal's Avatar
8,164, Level: 21
Points: 8,164, Level: 21 Points: 8,164, Level: 21 Points: 8,164, Level: 21
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 303, Got 155
ill post some pics of the lights i have behind my plasma. they are only one colour but look the nuts.
will charge the camera up tonight and then post some. after i have worked out how to post pictures on this board. i have tryed before and couldnt do it - im a thick o...
Dal
Old 01-04-2005, 3:23 PM   #4
4,961, Level: 16
Points: 4,961, Level: 16 Points: 4,961, Level: 16 Points: 4,961, Level: 16
Thanks: Gave 2, Got 6
Get some Philips with ambilight. That's exactly what you are asking.
Old 01-04-2005, 3:27 PM   #5
thegooseman
Posts: n/a
Ill give the phillips one a look in. where would they be situated? uplight or behind panel?
reson being, my pw7 is situated on a wall the same width between two windows, therefore sides would not really make much difference.
Where can I get the phillips ones from? any links?
Old 01-04-2005, 3:30 PM   #6
4,961, Level: 16
The lights aren't seen when you are facing the set: they're behind, one on each side, disposed vertically (i.e. the long edge of the lamp is on vertical).
If you don't want lights on sides, then forget the ambiligth. Link to this ambilight thing: http://www.flattv.philips.com/index...._id=2&page=pg3
Old 01-04-2005, 3:31 PM   #7
thegooseman
Posts: n/a
could I put them horizontal?
Old 01-04-2005, 3:38 PM   #8
4,961, Level: 16
No... the ambilight lamps are not movable.
So, you will need some devices that connects to an in/out scart, process the video, and drives multicolor lamps which you'll place below and above your set... difficult but not impossible.
Old 01-04-2005, 3:38 PM   #9
thegooseman
Posts: n/a
Thanx guys appreciate it.
I'll see what I can do.
I'll send some pics when Im done
Old 01-04-2005, 4:08 PM   #10
pioneerman's Avatar
5,546, Level: 17
Points: 5,546, Level: 17 Points: 5,546, Level: 17 Points: 5,546, Level: 17
Thanks: Gave 78, Got 55
Dal
i had probs at first but worked it out in the end you click on manage attachments and browse ie. "my pictures" and upload a pic you might have to resize them.
Old 01-04-2005, 4:14 PM   #11
w3dal's Avatar
8,164, Level: 21
Activity: 1.5%
be good to get some pics up on back lighting plasma screens.
Cheers for the info pioneerman ill give it a go, when i have taken some pics.
Old 01-04-2005, 4:56 PM   #12
Hitby's Avatar
7,163, Level: 20
Points: 7,163, Level: 20 Points: 7,163, Level: 20 Points: 7,163, Level: 20
Activity: 6.4%
Activity: 6.4% Activity: 6.4% Activity: 6.4%
Thanks: Gave 490, Got 406
I'd be very interested in how this turns out, the ambilight looks really cool!
Dan
Old 01-04-2005, 8:53 PM   #13
w3dal's Avatar
8,164, Level: 21
Activity: 1.5%
lighting as promised
hope this works -
Old 01-04-2005, 9:24 PM   #14
pioneerman's Avatar
5,546, Level: 17
lighting
what have you used for this and can you tell me where to get them from and how much, looks cool.
Old 02-04-2005, 8:23 AM   #15
w3dal's Avatar
8,164, Level: 21
Activity: 1.5%
Looks cool doesnt it.
There from Habitat and there called "Lighting Chain" "Pill" type.
Supposed to last for 20,000 hours.
They do them in a few other colours aswell. I have to admit though my Girlfriend bought them for me.
Dal
Old 02-04-2005, 6:49 PM   #16
15,008, Level: 29
Points: 15,008, Level: 29 Points: 15,008, Level: 29 Points: 15,008, Level: 29
Activity: 11.0%
Activity: 11.0% Activity: 11.0% Activity: 11.0%
Thanks: Gave 394, Got 156
That looks cool.... how is it when watching a fillm? Are they distracting, or am I being a bit stupid - do you turn them off then?
Old 02-04-2005, 11:49 PM   #17
w3dal's Avatar
8,164, Level: 21
Activity: 1.5%
i normally have them on when the plasma is off. just gives a nice light effect. could have them on with the plasma though.
Dal
Old 11-04-2005, 4:11 PM   #18
johnl937
Posts: n/a
Hi all, I put LED behind my plasma some time ago, looks fantastic anytime....
http://www.auroralight.co.uk/auroralight/home_scape.htm
Old 13-04-2005, 11:58 AM   #19
Xstyle's Avatar
12,026, Level: 26
Points: 12,026, Level: 26 Points: 12,026, Level: 26 Points: 12,026, Level: 26
Activity: 3.2%
Activity: 3.2% Activity: 3.2% Activity: 3.2%
Thanks: Gave 171, Got 103
AMAZING!!! The Ambient Lighting is so much better than static lights behind a plasma/lcd screen... changes colour with whats on the screen!
Where can U get them from???
My plasma will be flushed in the wall, with no edges... but I may rethink this now if I could have Ambient Lighting... maybe have an inch gap either side for the lights to have some effect (with plasma still rcessed in the wall)
Old 13-04-2005, 12:13 PM   #20
Xstyle's Avatar
12,026, Level: 26
Activity: 3.2%
Its only available to Philips http://www.av-sales.com/html/philips_32pf9986.html
as its an integral part of their TV screen.
Oh Well ... back to nothing then...
Old 14-04-2005, 9:16 PM   #21
samhain's Avatar
9,163, Level: 22
Points: 9,163, Level: 22 Points: 9,163, Level: 22 Points: 9,163, Level: 22
Activity: 6.4%
Thanks: Gave 124, Got 46
Let's say you just want a slight yellow (normal light colour) eminating from behind the plasma. This will apparently help the eye's pupil adjust to the dark conditions. It can often be distracting sitting in total dark with a screen only aglow. It always seems less tiring on the eye if there is a slight ambiant light behind the screen when watching it.
Any suggestions, presumably a very low intensity tube (strip) light would do. 6 Watts or something, with the bulb shielded from direct viewing giving a nice glow behind the screen
Old 15-04-2005, 7:22 AM   #22
Xstyle's Avatar
12,026, Level: 26
Activity: 3.2%
I'm instead planning to have a row of downlighters toward the back of the room, on "very low" dimmed above the seating area.....
that in my view would be a better idea...
Old 30-06-2005, 8:12 AM   #23
hpoom's Avatar
9,070, Level: 22
Points: 9,070, Level: 22 Points: 9,070, Level: 22 Points: 9,070, Level: 22
Thanks: Gave 36, Got 18
Would these be OK for making a DIY ambilight setup on a 32" LCD TV ?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...982127134&rd=1
After reading about DIY ablilight setups I thought fish tank lights would be perfect.
So would this be OK or am I better going to Habitat to get those Phil lights
Old 07-07-2005, 10:04 PM   #24
hpoom's Avatar
9,070, Level: 22
Can anybody else comment on their solutions to LCD TV backlighting ?
Old 17-01-2009, 6:00 PM   #25
1,262, Level: 8
Points: 1,262, Level: 8 Points: 1,262, Level: 8 Points: 1,262, Level: 8
Thanks: Gave 1, Got 0
Re: Backlighting
I am looking for a light unit to reflect changing colours onto the wall at the back of my TV. I saw this in use when visitng someones home. Never thought at the time to ask about the unit, and too far awawy to make another visit.
Some help would be much appreciated. Thankyou.
Regards, Snowballpals.
Old 17-01-2009, 7:56 PM   #26
3,081, Level: 13
Points: 3,081, Level: 13 Points: 3,081, Level: 13 Points: 3,081, Level: 13
Thanks: Gave 15, Got 53
Re: Backlighting
is this it,just a idea
Philips LivingColors Colour Changing Mood Lamp
YouTube - LivingColors at my place !!!
Old 18-01-2009, 8:37 AM   #27
10,890, Level: 25
Points: 10,890, Level: 25 Points: 10,890, Level: 25 Points: 10,890, Level: 25
Activity: 11.0%
Thanks: Gave 303, Got 113
Re: Backlighting
Dal
looks good...
tried to find it on their website but as usual 'search' facilities are top knotch........
brings up a massive selections of chairs!
anyone found it ....or something similiar.....and can provide a link?
cheers
Old 21-01-2009, 7:31 PM   #28
3,056, Level: 13
Points: 3,056, Level: 13 Points: 3,056, Level: 13 Points: 3,056, Level: 13
Thanks: Gave 28, Got 0
Smile Re: Backlighting
MOOD AMBIENT AMBILIGHT TV PLASMA LCD LIGHTS LIGHTING on eBay, also LED Lighting, Lights, Lighting, Home Garden (end time 05-Feb-09 08:49:30 GMT)
Old 23-01-2009, 11:48 AM   #29
2,581, Level: 11
Points: 2,581, Level: 11 Points: 2,581, Level: 11 Points: 2,581, Level: 11
Activity: 20.1%
Activity: 20.1% Activity: 20.1% Activity: 20.1%
Thanks: Gave 5, Got 6
Re: Backlighting
Damn thats expensive! thats £400 to light 4 sides of a bed :O
Old 24-01-2009, 9:45 AM   #30
10,890, Level: 25
Activity: 11.0%
Re: Backlighting
i agree......
still looking for a cheap solution
....anybody any pointers?
