I've bought a set of these and having been through various backlighting solutions I can say that hand on heart, these are by far the best solution that I've seen.
IMHO 60 LED/m are completely overkill, 30 LED/m works perfectly for all but the brightest of rooms (but then if your room is bathed in bright sunlight you probably won't be bothered about backlighting).
These make the previous Apollo light tubes sold on the forums look a poor and expensive comparison tbh...
supraTTman, I'm not sure if you know the answer to this question, but the white looks a little pink on my wall (it's jasmine white so not a pure white), and some of the default DIY modes look better. Is there any way to dim the DIY modes as this doesn't seem to work on my remote?
I'll get some pics up shortly of my setup...
