infrared 4 gang - dimming advice please - varilight/scenestyle/lutron?
Old 14-11-2009, 1:15 PM   #1
music's Avatar
5,739, Level: 17
Points: 5,739, Level: 17 Points: 5,739, Level: 17 Points: 5,739, Level: 17
Thanks: Gave 36, Got 14
i, I want a 4 gang/channel (is gang and channel the same thing?) remote control dimmer switch.
After much research I have honed it down to :
4 Gang 2 Way 250w IQ Master Remote Touch Dimmer Switch = approx £40
Scenestyle 4 channel = approx £320
Lutron rania Lutron Rania 4-Gang IR Remote Control Light Dimmer = Approx £250
I am tempted towards the Varilight, because of price! £250 - £300 seems eextortionate to me.
I only want to control lights in one large room being downlighters on two separate circuits a hanging light and 3 x wall lights.
Can anyone tell me if there are any significant downsides to Varilight. If not I think I would go with them and would save a few hundred pounds. I am less concerned about fancy scene settings etc. as thi9ngs that would bug the hell out of me like buzzing.
I am not sure if it’s better to go by way of mains downlighters or low voltage lights. I am told that low voltage lights can cause buzzing? – but also that low voltage lights are much more economical. I don’t want LED as the light they put out seems rather unnatural to me.
Any advice seriously welcome. Please.
My ceiling area is 16 foot by 40 foot. Is there a recommended downlighter calculation based on ceiling area???
Old 14-11-2009, 10:57 PM   #2
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
Re: infrared 4 gang - dimming advice please - varilight/scenestyle/lutron?
Gang and channel amy or may not be the same if you want to control 4 seperate channels of lighting with seperate scene levels its lutron or mode, if you want the same operation of 4 channles you can use cheaper alternatives
