Originally Posted by shahedz for my tank, i was told by a few people , keeping the tanking ticking over at one temp was more efficient than heating up a tank, letting it cool down than having to heat it all up again.
This reminds of my arguments with my ex. I could not convince her that its cheaper to run if you let it cool down....
Hot things loose energy (money) much faster the hotter they are. In fact I think heat energy loss is directly proportional to the relative temperature of the tank to its surroundings. eg If the tank of water was as cold as the room its in then it can't loose any more heat therefore costs nothing to keeping ticking over at room temperature. Heating it up to working temperature from cold isn't wasting money because the energy used to heat it up is stored in the water and you get it back later in the form of hot water. Only the
lost heat through the insulation is costing money because that's wasted heating the room up, and the hotter the water is the faster it will be loosing energy (money) to its surroundings.
Heating a tank of water is not analogous to a motor car, were cruising at steady speed is the most economical way to travel.
Have I still failed to convince?
