Double pole IR switch
Old 11-11-2009, 10:10 AM   #1
A-F A-F is offline
1,284, Level: 8
Points: 1,284, Level: 8 Points: 1,284, Level: 8 Points: 1,284, Level: 8
Thanks: Gave 2, Got 11
Hi, I'm trying to find a double pole ir wall switch and not having much luck. Does anyone know if they exist?
I need it to control an electric motor - the double pole is so i can reverse the polarity and change the direction of the motor.
Old 13-11-2009, 10:29 AM   #2
A-F A-F is offline
1,284, Level: 8
Re: Double pole IR switch
Ok, does anyone know if I can do this by using a standard infrared wall switch and some kind of relay setup - this is beyond my electrical knowledge. Any help really appreciated.
