Anyone got Scenestlye2 lighting from ModeLighting?
Old 07-11-2009, 1:12 PM   #1
KhalJimbo's Avatar
20,429, Level: 34
Points: 20,429, Level: 34 Points: 20,429, Level: 34 Points: 20,429, Level: 34
Activity: 18.2%
Activity: 18.2% Activity: 18.2% Activity: 18.2%
Thanks: Gave 1,009, Got 603
I have the Scenestyle2 dimmer, works great no problem..............until this morning!
All I did was turn the lights off on the dimmer, then go to the main switch board of the house and turn the power off to the lighting circuits, changed the lights and now nothing. The Scenestyle dimmer is just dead as a dodo, no lights nothing, but when I put a voltage meter to the dimer it shows there is power, there is also power to each of the light cables but for some reason the dimmer wont turn on?!?!
Any ideas, I'm at a total loss here
Old 07-11-2009, 4:47 PM   #2
1,902, Level: 10
Points: 1,902, Level: 10 Points: 1,902, Level: 10 Points: 1,902, Level: 10
Thanks: Gave 2, Got 29
Re: Anyone got Scenestlye2 lighting from ModeLighting?
You say you have changed the lighting on the circuit? Is whatever you've changed it to actually dimmable? sounds like you've put a non-dimmable light on the circuit perhaps...
Old 08-11-2009, 9:30 AM   #3
KhalJimbo's Avatar
20,429, Level: 34
Activity: 18.2%
I worked it out, the dimmer needs at least 50w on each circuit, I had 3 lights of 9w each, so I put different lights on with a rating of 50w esach and it came back on
