I too have wrestling with the options for dimming energy saving bulbs. I have pretty much decided that I want to install a Rako system for full scene-based lighting control but the difficult part is choosing the right bulb/dimmer combination in light (no pun intended) of the recent EU legislation.
My problem is that I will be using open drum lamp shades which mean that the bulbs will be in direct view. I therefore want a diffuse / frosted bulb. I also want 100 Watt equivalent bulbs (anything less is just too dim).
Options I have considered are:
- Traditional 100W incandescent bulbs but these are banned and now in short supply.
- 70W halogen GLS style bulbs (as discussed above). These looked like the best solution until I discovered that the frosted versions of these have also been banned. Additionally, it is my understanding that all halogen bulbs will be gradually phased out (banned) between now and 2013 and I don't want to invest in all the Rako gear only to find that I can't get compatible bulbs only a few years down the road and have to change the dimmer units.
- Megaman "Dimmerable" CFLs controlled by the Rako "RDL500 CFL" dimmer. The problem with this option however is that Megaman don't actually make any 20W dimmerable bulbs.
- Other manufacturer's 20W Dimmable CFLs, but I don't know which Rako dimmer to use?
neilball and gtg60, can I ask you both what model of dimmers you were using with your dimmable CFLs?
Also, does anyone have specific experience of using the Rako "RDL500 CFL" dimmer, either with Megaman "Dimmerable" CFLs another manufacturer's dimmable CFLs?
Many Thanks,
z
