Harmony one and lighting
Old 27-10-2009, 11:26 PM   #1
1,345, Level: 8
Points: 1,345, Level: 8 Points: 1,345, Level: 8 Points: 1,345, Level: 8
Thanks: Gave 10, Got 8
Hi All
New member here, well been a guest for a while..
Hope i posted in the correct section as i posted this in the wrong section about 2 mins ago, ooops (sorry mods)
In my living room we have 1 ceiling light and 3 wall lights, is there anyway of controlling all 4 lights from a harmony one remote ?
Ive seen the varilight but not sure if it can control 4 lights.
Thanks in advance
Riks
Old 28-10-2009, 12:40 AM   #2
vipergrm's Avatar
12,172, Level: 26
Points: 12,172, Level: 26 Points: 12,172, Level: 26 Points: 12,172, Level: 26
Activity: 28.4%
Activity: 28.4% Activity: 28.4% Activity: 28.4%
Thanks: Gave 297, Got 424
Re: Harmony one and lighting
Originally Posted by r1984 View Post
Hi All
Thanks in advance
Riks
You can control as many lights as you want as long as you allocate individual buttons for each light. I guess you already have the remote control for the lights so if your lighting system is not on the Logitech database then the Harmony will happily learn each command manually. You could use an activity and use numbers to correspond with the lights or pretty much set it up whichever way you like. Of course, the lights must have an IR sensor
Old 28-10-2009, 12:57 AM   #3
Assured Advertiser
hornydragon's Avatar
63,997, Level: 61
Points: 63,997, Level: 61 Points: 63,997, Level: 61 Points: 63,997, Level: 61
Thanks: Gave 102, Got 1,406
depends on the wattage of each fitting and the current wiring, short answer is yet, the devil is in the detail!
Old 28-10-2009, 6:09 PM   #4
1,345, Level: 8
Which one can you recommend for me to use, to control 4 lights ?
Old 29-10-2009, 9:50 PM   #5
Assured Advertiser
63,997, Level: 61
My vote would be Mode scenestyle Welcome to SceneStyle.co.uk - The Stylish Way To Control Your Lighting
