Global Cache Itach
Old 20-10-2009, 2:03 PM   #1
3,867, Level: 14
Points: 3,867, Level: 14 Points: 3,867, Level: 14 Points: 3,867, Level: 14
Thanks: Gave 30, Got 22
Global Cache Itach
Has anybody yet had an oppotunity to play/install/view the itach wifi modules?
PR: Global Caché Launches iTach Family of WiFi and Ethernet Connectivity Products
Fulltopuk
Old 26-10-2009, 1:04 PM   #2
bail0ut's Avatar
1,252, Level: 8
Points: 1,252, Level: 8 Points: 1,252, Level: 8 Points: 1,252, Level: 8
Thanks: Gave 0, Got 3
Re: Global Cache Itach
Not yet, but I'm patiently waiting for an email back from Sonluce telling me they've arrived in stock. Will report back in due course.
Fulltopuk (30-10-2009)
Old 22-01-2010, 3:34 PM   #3
3,867, Level: 14
Any more news on Itach?
Old 08-03-2010, 4:47 PM   #4
bail0ut's Avatar
1,252, Level: 8
Amazing - buy one! And before you ask no I'm not affiliated with Global Cache.
I bought the wifi2ir model which is perfect for controlling my kdl-w4500 bravia, denon avr2802 and sky+hd box. Although prepare to spend some time tinkering with commandfusion's guidesigner getting button configurations setup to suit you tastes.
Now I can't wait to get my hands on an iPad as that will look way better sat on my coffee table than my beat up iphone.
Roll on end of april...
Fulltopuk (08-03-2010)
Old 11-03-2010, 4:37 PM   #5
3,175, Level: 13
Points: 3,175, Level: 13 Points: 3,175, Level: 13 Points: 3,175, Level: 13
Thanks: Gave 8, Got 5
Really - what software are you using to control the iTach.
I'm thinking of either that or the GC-100 as I could do with a serial port control as well.
Old 24-03-2010, 4:14 PM   #6
bail0ut's Avatar
1,252, Level: 8
I'm using commandfusion's iviewer. If you need RS232 then a GC-100 would most likely be a better option. But if you did buy an ir itach you can always add extra units a later date for rs232 or relay. Another really cool feature with the itach is that it can be powered via usb so I have mine plugged into my skyhd box drawing power from it's unused usb port. Result
