IR Repeater - What are the current best repeaters on the market?
Old 19-10-2009, 4:42 PM   #1
bazza2000's Avatar
2,330, Level: 11
Points: 2,330, Level: 11 Points: 2,330, Level: 11 Points: 2,330, Level: 11
Thanks: Gave 10, Got 1
I've had a good look through the forums, but a lot of the post appear to be old circa 2003-2006 in relation to the best IR repeater currently on the market.
What I'm planning to do is setup an screen in a false chimney breast, however, I have a room directly behind which will house the AV kit. This does mean that I could drill a hole through the wall for cables if required, so not just restricted to wireless repeaters.
In terms of AV kit, I have (or will have) to control Sky+ HD, Home Cinema, PS3, HTPC. Primary focus is on the Sky+ HD for the missus and based on this I would require the Sky remote to work also.
Anyway, my question is, what is the best solution wired/wireless? and where can I get them.
Thanks,
Bazza.
Old 19-10-2009, 5:08 PM   #2
drivinscool's Avatar
7,095, Level: 20
Points: 7,095, Level: 20 Points: 7,095, Level: 20 Points: 7,095, Level: 20
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 157, Got 157
Re: IR Repeater - What are the current best repeaters on the market?
Don't know which is best but i've been using a Marmitek for a couple of years and it's pretty strong. It is wired though. Just wish it was multi-directional at the receiver as I have to turn it by 90 degrees when in the conservatory/garden.
So possibly not the product your after but brand/build wise i'm happy with it.
bazza2000 (21-10-2009)
